Front fuel tank leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-13-2012, 05:06 PM Thread Starter
Robjesup88's Avatar
After filling up the front tank, I noticed a spot on the driveway. So this morning i unbolted the bed and slid her back ... Dry around filler hose port, vent hose port, sending unit.. It appears leak is on the seam on the front or at the top where it may have rubbed a hole on the cross brace, either way it has to be replaced... Is there much of a difference in the quality in the tanks from LMC verses O'Reilly or autozone, and the 19 gal tank is for the crewcab lb, and the 16 gal tank is for the shortbed correct ???
92 F150 rcsb E4od 5.0 sold
97 f350 cclb E4od 7.3 sold
07 f250 King Ranch studs and deleted
Robjesup88 is offline
post #2 of 7 (permalink) Old 10-13-2012, 06:06 PM
Fixing Broken Stuff
toolmangary's Avatar
Re: Front fuel tank leak
Usually here up north the front tanks rot at the seam while the rear tanks rot between the straps and the tank. I'd bet all those company's sell Spectra tanks. I think only the short bed regular cabs had a 16 gallon front tank. The rear 19 gallon tank can be replaced with a 38 gallon tank, I have done it to my trucks, easy to do.
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #3 of 7 (permalink) Old 10-13-2012, 09:46 PM Thread Starter
Robjesup88's Avatar
Yes toolman, I bought the 19 gallon Spectra brand from autozone $129.99... After transfering the fuel to the rear tank, I dropped the tank and found the TWO leaks, one on the front seam and the other at the top under the cross brace. when i pulled the sending unit, the fuel pick up screen was completely covered with sludge. It almost felt like slime.
post #4 of 7 (permalink) Old 10-13-2012, 11:40 PM
STILL LEARNING
Bradbilt's Avatar
Certain trucks got a Poly front tank. I would love to find a used one but the junk yrard by me has never even seen one. It thing JBG sells them new
Bradbilt is offline
post #5 of 7 (permalink) Old 10-15-2012, 01:30 AM Thread Starter
Robjesup88's Avatar
Got my new front tank installed ....
post #6 of 7 (permalink) Old 02-13-2016, 06:20 PM
flmeade's Avatar
1997 F350 duelly with standard cab and 8 ft. bed. Front tank is leaking at the seam and I can't find anyone who can give me a part number or size of this tank, not even the dealers. Anyone got any info on this tank and where to get it. It also has a fuel leak somewhere on the passenger side of the engine. There is no fuel in the valley.
1999 F250 7.3, 6 speed manual
flmeade is offline
post #7 of 7 (permalink) Old 02-13-2016, 11:05 PM
csp
Front tank is the same on any longbed, doesn't matter if it's SRW or dually. Not sure why you can't find one. Rock Auto is the only site I looked at and they have them. Many places list them as a side mount.
csp is offline
