Come home from deployment now damn truck won't start! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-12-2012, 09:16 PM Thread Starter
Unhappy Come home from deployment now damn truck won't start!
So, I've been gone for about a year playing in the sandbox across the pond. My truck was left with my father who drove it once or twice a month to keep all the right juices flowing in the right spots.
Long story short, I've tried and trouble shot a bunch of ####, and I can't get my injectors to cycle/prime upon turning the key.
Is it worth playing with the IPR or ICP, or what? I'm kinda stuck in the driveway as it will crank till the batteries are dead, but won't make one puff of smoke.
If anyone could point me in the right direction I'd really appreciate it (and buy you a beer if you're ever in my neck of the woods!)
USMCNICK is offline
post #2 of 13 (permalink) Old 10-12-2012, 09:38 PM Thread Starter
Re: Come home from deployment now damn truck won't start!
Well, I don't know why my signature isn't showing up, but the truck is a 97 crewcab 5 speed, 4.10 gears. Beans "tranny saver" injectors.
1997 250 CC
5 speed, 4.10
Beans "Tranny Saver" +30 injectors
Straight pipe from the turbo back.
USMCNICK is offline
post #3 of 13 (permalink) Old 10-12-2012, 09:42 PM
What do you mean cycle/prime your injectors?
Are your glowplugs working? Have you tried plugging it in then starting it?
Have you checked all fuses under the dash and under the hood?
02 f250
countryboyrob is offline
post #4 of 13 (permalink) Old 10-12-2012, 10:02 PM
whistle tits
ghohouston's Avatar
What he said, and maybe check your oil... Pull fuel filter too and see if thwres fuel in the bowl, of.course providing all fuses and such are good.
ghohouston is offline
post #5 of 13 (permalink) Old 10-12-2012, 10:38 PM Thread Starter
Yup - new fuel filter, has the correct amount of oil, it will fill the fuel bowl up after I drain it. I tested my glow plug relay and the glow plugs (with multi meter, without taking them out). I have checked all the fuses, and have switched out all the relays (40A, 5 pole in the fuse box under the hood, and the 2 next to the fuse box) one at a time to see if that would rule out anything.
By "Cycle" I mean I cannot hear them when I turn the key to the "ON" position.
1997 250 CC
5 speed, 4.10
USMCNICK is offline
post #6 of 13 (permalink) Old 10-12-2012, 10:46 PM
whistle tits
ghohouston's Avatar
Pull hpop fill plug in the top of hpop resovoir and check level. Shouldnt be but around 1/2 low
post #7 of 13 (permalink) Old 10-12-2012, 10:47 PM
STILL LEARNING
Bradbilt's Avatar
This is NOT a 6.0, you dont hear the injectors
Bradbilt is offline
post #8 of 13 (permalink) Old 10-12-2012, 10:51 PM
whistle tits
ghohouston's Avatar
X2
post #9 of 13 (permalink) Old 10-12-2012, 10:51 PM Thread Starter
Ah. Well that explains something then. Haha. The only diesels I've been around for the past while are big CAT engines, and I'm trying to remember about these 7.3s.
1997 250 CC
5 speed, 4.10
USMCNICK is offline
post #10 of 13 (permalink) Old 10-12-2012, 10:58 PM Thread Starter
Well, pulled the plug on the HPOP, couldn't see much even with a light. Took a pipe cleaner to gauge the oil - annnnnnd it came out bone dry with the exception of about 1/8" of oil on the very bottom. Any direction?
1997 250 CC
5 speed, 4.10
USMCNICK is offline
