wont start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-11-2012, 09:43 PM Thread Starter
joemx611's Avatar
wont start
i already posted before about a month ago.. but sdince then my computer has died also and i just got a new one today.. but myu problem is, i got a 95 and i went to use it to jump start my 94 and once i got the 94 started i turned off the 95 and when i went to start it the next day to move it, it just cranks and cranks but i get nothin. i have power to my glowplug relay, no white smoke, and my tack does move a little while its cranking, and i dont have any blown fuses.. i hated to do it but i even gave it a small shot of either and still nothing.. any advice would be greatly appreciated and again sorry to post twice about the same thing
08 6.4 king ranch 4 door long bed, play truck with all the goods
05 6.0 single cab flatbed, bullet proofed work truck
joemx611 is offline
post #2 of 6 (permalink) Old 10-11-2012, 10:30 PM
theoldgirl1990's Avatar
Re: wont start
Sounds like you are not getting fuel to the cylinders. So that probably rules out a glow plug issue due to no smoke out the tailpipe. I think it is high pressure oil related. I had the same thing happen to mine. One morning it would not start because the high pressure oil system wasn't pressurizing. I found out the ipr was faulty, I replaced it and it started. So I would get a code scanner on there and check your high pressure oil pressures on start up. If they are under 500 psi, then you have a high pressure oil problem. IPR or icp would be a good first place to look. Try unplugging the icp sensor next time you start it. It should default to about 1000 psi. The icp sensor is located on the drivers side head.
1996 F-350 cclb, H2E, e-fuel, srp1.1, custom tuning, banks intercooler, 3 in plenums, swamps babies, ARP's, comp 910's, Isspro EV2's, rsk v/c codes, 5 inch exhaust, king ranch seats, SD 10.5 axle, swamps idm, 6.0 fan, international w/p, hydroboost, SD trans lines, 6.0 trans cooler,6.0 P.S. pump
theoldgirl1990 is offline
post #3 of 6 (permalink) Old 10-11-2012, 10:37 PM
Re: wont start
Is the '94 truck a PSD?
madpogue is offline
post #4 of 6 (permalink) Old 10-11-2012, 11:26 PM Thread Starter
joemx611's Avatar
Re: wont start
what exactly is the ipr or the icp? and no the 94 is a 7.3 idi
joemx611 is offline
post #5 of 6 (permalink) Old 10-11-2012, 11:33 PM Thread Starter
joemx611's Avatar
Re: wont start
is the plug your talking about on the driverside head up next to the fuel bowl? becasue i unplugged that and it still didnt start and i had no movement on the tack with that unplugged
joemx611 is offline
post #6 of 6 (permalink) Old 10-12-2012, 05:10 AM
Re: wont start
Your IPR is your injector pressure regulator. It controls pressure from the high pressure oil pump. The ICP sensor is the injector control pressure. You could have a bad cam sensor if your tachometer is not moving. It is a common problem with the 7.3 powerstrokes.
