4wd shift lever all over the place - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-10-2012, 06:59 PM Thread Starter
Still a kid to some ppl
oldfordisbetter's Avatar
Worked fine during testdrive. Now that i got it home n all i went to use it in 4wd yesterday to pull a tree i cut down into the woods. I go to put it in 4lo n the shifter is all of a sudden all over the place and wouldnt engage correctly. It went in and i got the job done but it took almost a half hour to get it bak in 2hi. Whatever holds it in a straight line broke or is missing somehow. It moves left n right and up n down. . Whats wrong with it?
1997 eclb xlt. 2.5 "toughcountry, 5100 shocks, 35s
Tymar intake, 5" straight pipe, ww2
Baby swamps, custom ts6,
Rebuilt trans w/valve body
Ats tq conv
oldfordisbetter is offline
post #2 of 8 (permalink) Old 10-10-2012, 08:07 PM
STILL LEARNING
Bradbilt's Avatar
Re: 4wd shift lever all over the place
Could be a couple things. You will have to lay under the truck and look at it
Then read this
4WD Shifter repair - PowerStrokeNation : Ford Powerstroke Diesel Forum
Bradbilt is offline
post #3 of 8 (permalink) Old 10-12-2012, 01:57 AM Thread Starter
nor quite sure what im looking at or for...
Ats tq conv
post #4 of 8 (permalink) Old 10-12-2012, 02:21 AM
STILL LEARNING
Bradbilt's Avatar
Looks like you need to do my fix
In that 1st pic you can see the broke cast aluminum
Bradbilt is offline
post #5 of 8 (permalink) Old 10-12-2012, 03:00 AM Thread Starter
i see it now yes.
Ats tq conv
post #6 of 8 (permalink) Old 10-12-2012, 12:34 PM
Demon Dually
speeddemon31176's Avatar
Get a new shifter assembly and before installing it disassemble it and drill the outer housing and add grease zerks so you can keep it lubed to prevent this from happening again.
speeddemon31176 is offline
post #7 of 8 (permalink) Old 10-13-2012, 07:39 PM Thread Starter
Will a shifter assembly from a 1988 bronco work? My old bronco is sitting there all alone rotting away.
Ats tq conv
post #8 of 8 (permalink) Old 10-13-2012, 07:55 PM
STILL LEARNING
Bradbilt's Avatar
You may have to modify the linkage but it should bolt on
Bradbilt is offline
