Are wheel arches identical height wise front to rear? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-10-2012, 09:12 AM Thread Starter
Coueshunter's Avatar
I have the front lifted and on the ground. Was wondering if height wise the wheel arches are identical front to rear. If I measure 46" in the front, is 46" going to make the truck sit level in the rear?
It appears to me they are the same front to back but I figured I would ask and double check. Once my rear spring is installed in ordering a custom block for the rear to make the truck perfectly level.
Back the Blue BUILD THREAD
POWERSTROKENATION-
Facebook-
Coueshunter is offline
post #2 of 6 (permalink) Old 10-10-2012, 12:08 PM
STILL LEARNING
Bradbilt's Avatar
Re: Are wheel arches identical height wise front to rear?
No. The fronts are bigger You really need to measure from the top body line. When a truck sits perfectly level, the rear looks lower because the rear tire is more stuffed
Bradbilt is offline
post #3 of 6 (permalink) Old 10-10-2012, 03:11 PM
Could you put a level along the top of the bed rail?
96 F250 CCSB 4x4, D60, 3.55, Auto, 6.0 trans cooler 3"-4" down pipe & exhaust, not enough power
wildstang is offline
post #4 of 6 (permalink) Old 10-10-2012, 04:58 PM
STILL LEARNING
Bradbilt's Avatar
I think it is sitting in his driveway which is not level
Bradbilt is offline
post #5 of 6 (permalink) Old 10-10-2012, 04:59 PM Thread Starter
yep... Thats the problem..
Ill measure from the upper body line to the ground then and see what it is. The distance looks VERY close for the wheel arches though.
POWERSTROKENATION-
Facebook-
post #6 of 6 (permalink) Old 10-10-2012, 05:11 PM
That complicates it a little
