fuel reset light - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-10-2012, 05:02 AM Thread Starter
fuel reset light
I've got a 94 f250 and the fuel reset light on the dash next to where the left turn signal indicator is. I was wondering what causes this light. I've searched but haven't been able to find an answer so far. If the key is not even in the truck and you open the door the light begins flashing. Thanks for the help
Ks94.5powerstroke is offline
post #2 of 8 (permalink) Old 10-10-2012, 05:07 AM
Demon Dually
speeddemon31176's Avatar
Re: fuel reset light
Fuel reset light? There is a water in fuel light but that is on the right side of the column on the secondary panel only populated in diesel trucks.
speeddemon31176 is offline
post #3 of 8 (permalink) Old 10-10-2012, 05:44 AM Thread Starter
Here's a picture of it ( sorry couldn't get a better one the flash made it so you couldn't see anything).photo(3).JPG
post #4 of 8 (permalink) Old 10-10-2012, 06:26 AM
bracketracer's Avatar
I'm thinking that someone swapped your instrument trim panel for a gasser panel?
Does the fuel reset light stay lit for a minute after you turn the engine off and lock the doors with the power locks?
Newest project: 1995 F350 CC/DRW 2WD E4OD. 3" DP, 4" Diamond Eye system. But I'm still fixin' the broken stuff......
bracketracer is offline
post #5 of 8 (permalink) Old 10-10-2012, 06:35 AM Thread Starter
Not positive on the staying on part I cant remember for sure I'll have to check on it tomorrow. I know that if i open the door it will start but as soon as its shut it goes off...is there anyway to tell if that is what has gone on for sure? Thanks for the help.
post #6 of 8 (permalink) Old 10-10-2012, 06:55 AM
It's behaving like an anti-theft light, which would be in the position next to the left turn indicator. If that's what it is, it will light solid after you shut the engine down and close and lock the doors.
If the trim panel was replaced with the wrong panel, some of the indicators have different uses.
Any other clues that the dash trim was swapped? Does the wait to start module look "hacked" into the dash? A factory install looks seamless. If it's been cut in it should be obvious.
post #7 of 8 (permalink) Old 10-10-2012, 04:39 PM Thread Starter
Well it didn't stay on when I locked the doors today but, the wait to start area does look hacked up, and it is definitely acting like an anti -theft light. There's some weird plug in to the right of the actual wait to start light for some reason it won't let me attach a picture right now of it. But, basically it seems like someone switched it out with a different truck, so basically it's just the anti-theft light with the wrong face to it correct?
post #8 of 8 (permalink) Old 10-11-2012, 03:55 AM
Yeah, that's what I'm thinking.
Does your truck have keyless entry also?
