01 Heads on a 96. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-10-2012, 03:55 AM Thread Starter
Learning
strokin n smokinn's Avatar
01 Heads on a 96.
I got a 96 7.3 and the heads had a hole in them. I have the motor out of the truck right now and the heads off. I happen to have a set of 01 heads off a 7.3. I heard all the heads are interchangeable. But I wasnt sure if the head bolts, head gaskets and manifolds were all the same. Just wondering what parts to order? Thank you
1996 Ford F-250 4x4 ECLB, 136k. E40D Tranny. Just the basics. 6637 Intake. 4 inch to 7 inch stack. Ts 6 position chip.
strokin n smokinn is offline
post #2 of 5 (permalink) Old 10-10-2012, 05:11 AM
Demon Dually
speeddemon31176's Avatar
Re: 01 Heads on a 96.
Same heads newer engine is all. The only difference between the 94.5-03 engines is that when they went to the superduty in the early 99 superduty they eliminated the hole in the valley for the mechanical fuel pump as they went electric and they changed the accessories around on the front of the engine. The heads are the same. Some internals such as the connecting rods were changed to powdered rods from forged rods.
speeddemon31176 is offline
post #3 of 5 (permalink) Old 10-10-2012, 05:08 PM Thread Starter
Learning
Okay thank you. So i will just put the 96 manifolds on.
post #4 of 5 (permalink) Old 10-10-2012, 05:26 PM
STILL LEARNING
Bradbilt's Avatar
You are not going to use the heads you got from me?
Bradbilt is offline
post #5 of 5 (permalink) Old 10-12-2012, 07:39 PM Thread Starter
Learning
They wanted too much to reman them.
