Doors & ignition on the same key - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-10-2012, 12:58 AM Thread Starter
Ok so my truck has had a steering column replaced along with a new set of door lock cylinders at a different time. A this point I don't even have a door key and I'd like to buy a matched set with a new ignition lock cylinder. I've rekeying quite a few dodge and jeep ignition cylinders, do the ford cylinders work on the same process. Ie can I buy a new set of door cylinders and key my ignition to match?
loudmouth is offline
post #2 of 3 (permalink) Old 10-10-2012, 05:01 AM
Demon Dually
speeddemon31176's Avatar
Re: Doors & ignition on the same key
If the ignition cylinder is working fine then just take the key for the ignition into any reputable locksmith along with the door cylinders which you can pull right there at their place of business and they can re-key the door cylinders to match the ignition for about 50 bucks or so.
speeddemon31176 is offline
post #3 of 3 (permalink) Old 10-10-2012, 12:49 PM
Patrick Feeley's Avatar
You can always try getting a set from Ford. This is what I have for trucks until 2/95 without anti-theft ... should have similar or same for later:
Lock Set, Door and Ignition
(Ford) F4TZ-1522050-B
Cheers!
Patrick Feeley is offline
