Roof leaking by windshield and small rust hole. HELP! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-09-2012, 11:07 PM Thread Starter
I have a 95 f350 crew cab and have water leaking into the cab thru the pinch weld where the windshield sits. Had the windshield replaced and re sealed and that surface is good. Im pretty sure the water is leaking in thru the silicon on the drip edge over the doors. Also have small rust hole over the passenger door starting. Has anyone gone thru this before and whats the best way of stopping this leak?
tomfqno is offline
post #2 of 7 (permalink) Old 10-09-2012, 11:12 PM
STILL LEARNING
Bradbilt's Avatar
Re: Roof leaking by windshield and small rust hole. HELP!
If your seam sealer is cracked in the drip edge, then that is somewhere to start. You need to carve it ALL out. When you get it ALL out I would paint it with an epoxy prime or some POR15.(providing you take care of any rust) Then scuff with a red scotch brite pad. I would go with the 2 part Heavy bodied seam sealer since that is designed to be so thick.
Where is the rust hole over the door? In the roof, door jam, drip rail?
Pics are always good
Bradbilt is offline
post #3 of 7 (permalink) Old 10-09-2012, 11:35 PM Thread Starter
Rust hole is in the roof above the drip edge.
tomfqno is offline
post #4 of 7 (permalink) Old 10-10-2012, 03:32 AM
STILL LEARNING
Bradbilt's Avatar
You are going to have to CUT that out and WELD in or panel bond a new piece in
Bradbilt is offline
post #5 of 7 (permalink) Old 10-10-2012, 11:01 PM Thread Starter
Thats what I was planning on doing. is there anywhere else other than the drip edges that I will need to re silicon?
tomfqno is offline
post #6 of 7 (permalink) Old 10-11-2012, 12:28 PM
STILL LEARNING
Bradbilt's Avatar
NOT silicone. You do NOT want silicone.
Anywhere the roof meets the cab, there will be seam sealer
Bradbilt is offline
post #7 of 7 (permalink) Old 10-16-2012, 01:38 PM
For sure want to use seam sealer and not silicone.
fordboy is offline
