pulling the trans - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-09-2012, 09:57 PM Thread Starter
hunter scar's Avatar
pulling the trans
hey guys im fixing to put a flywheel and clutch in my truck, i was wondering how many bolts are in the top of the bell housing and how hard is the trans to pull in these trucks. thanks hunter
1997 f250 ex cab short bed 4x4, 5 speed, tymar intake, 3inch mbrp downpipe to 5inch straight pipe, 2inch rough country front add a leafs. more to come. Totaled
2002 f250 ex cab short bed 4x4, 6 speed, tymar intake, 4inch downpipe to 5inch strightpipe, leveling kit ,issapro ev2 boost and pyro, PHP Hydra
hunter scar is offline
post #2 of 11 (permalink) Old 10-09-2012, 10:02 PM
STILL LEARNING
Bradbilt's Avatar
Re: pulling the trans
6 bolts total. 2 on top
Pretty easy to pull, just hope you have a jack that will reach high enough
Bradbilt is offline
post #3 of 11 (permalink) Old 10-09-2012, 10:02 PM
csp
I don't recall how many bolts, I think it's four that are accessed from the top. Raise the back of the transmission/transfer case up and you'll have better access to the top bolts from the engine bay side.
With a real trans jack it's easy to pull it.
csp is offline
post #4 of 11 (permalink) Old 10-09-2012, 10:16 PM Thread Starter
alright thanks guys. im paying to take a continuing ed class at the local community college and they have about every kind of tool their so maybe the will have a good trans jack. Should i go ahead and put a rear main seal in while im at it to?
post #5 of 11 (permalink) Old 10-09-2012, 10:20 PM
STILL LEARNING
Bradbilt's Avatar
If it is not leaking, dont touch it
Bradbilt is offline
post #6 of 11 (permalink) Old 10-09-2012, 10:48 PM Thread Starter
thanks for the help guys
post #7 of 11 (permalink) Old 10-10-2012, 02:03 AM Thread Starter
also should i change my clutch fork while im in their to?
post #8 of 11 (permalink) Old 10-10-2012, 02:17 AM
Patrick Feeley's Avatar
I always replace the release lever while I'm in there (it's only about $20). Cheers!
Patrick Feeley is offline
post #9 of 11 (permalink) Old 10-10-2012, 03:03 AM
Dont try and take the trans off with the transfer case still attached tried that the first time and it almost fell off the jack.
97 F350 CCLB zf5 4x4 PSD,South Bend Clutch, 6637, 10k, E-Fuel, Fast fill, 3"dp to 5" straight pipe, ebpv delete, home made bellowed up pipes
91 F250 ECLB zf5 4x4 IDIT, Flatbed, 93 front clip
88 F350 C&C RCLB zf5 4x4 460 Dually
93 F150 ECSB e4od 4x4 302 7'' lift
76 F150 RCLB c6 4x4 390fe
91F250XLIDI is offline
post #10 of 11 (permalink) Old 10-10-2012, 05:25 AM
Demon Dually
speeddemon31176's Avatar
OK step by step. First disconnect the batteries. Then unbolt the starter and let it hang. Then unbolt and move the exhaust out of the way. Next disconnect and relocate the wiring. Next unbolt the front and rear drive shafts after blocking the wheels to prevent the vehicle from rolling. You only need to unbolt the front drive shaft at the transfer case as well as the same for the rear drive shaft. On the rear drive shaft if your truck has a carrier bearing assembly, remove one bolt and loosen the other so you can swing the drive shaft out of the way for transfer case removal. Next disconnect the transfer case shifter(two 8mm bolts on 1356 or one 13mm nut on 4407 transfer case) and push shifter up out of the way. Next is to pop the shift linkage off at transfer case. Then unbolt the six 13 mm bolts holding transfer case to transmission. Remove transfer case. Next place a jack under the transmission and put minor pressure on it. Unbolt the transmission cross member and remove it as well as the skid plate. 4 10mm bolts on skid plate and 6 15mm bolts with 18mm nuts for cross member and two 18mm nuts for transmission mount. Next jack up transmission and remove cross member. Gently lower the jack until you can see the bell housing bolts. Using a long extension, swivel and short socket with an impact gun you can now remove the bell housing bolts. once removed you can slide the transmission back and lower it. Oh I almost forgot, you need to disconnect the slave cylinder and the shifter for the transmission first.
speeddemon31176 is offline
