HPOP??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-09-2012, 07:06 PM Thread Starter
Etaylor0056
Etaylor's Avatar
HPOP???
Got a nice 97 Powerstroke that will start and idle good. But as soon as you step on the GO pedal it dies??? Whats the problem here? Truck has 155k miles.
Etaylor is offline
post #2 of 7 (permalink) Old 10-09-2012, 07:10 PM
whistle tits
ghohouston's Avatar
Re: HPOP???
Providing your fuel filter is clean, and fpr screen is clean, the truck needs a scaner on it. Tgeres way too many possibilities guessing
ghohouston is offline
post #3 of 7 (permalink) Old 10-09-2012, 08:19 PM
Bugman's Avatar
Re: HPOP???
The first thing that I would check is the fuel pressure.
Bugman is offline
post #4 of 7 (permalink) Old 10-09-2012, 08:54 PM Thread Starter
Etaylor0056
Etaylor's Avatar
Re: HPOP???
10-4... I should have known that. What the deal is- Im looking at buying this one. And the ad said mechanical issues. So i called and the described the issue to me. He said that he put new filters in it not to long ago and thats all he done. wants to get rid of it b4 he sinks alot of money into it. The way you check the fuel pressure is on the side of the fuel filter bowl theres a pressure fitting just like a tire. just check it there??? what should it be reading???
Etaylor is offline
post #5 of 7 (permalink) Old 10-09-2012, 09:24 PM
whistle tits
ghohouston's Avatar
Re: HPOP???
Yes its the schrader valve on the side of the fuel bowl. Should be at least 40 psi
post #6 of 7 (permalink) Old 10-09-2012, 09:56 PM
STILL LEARNING
Bradbilt's Avatar
Re: HPOP???
Just had to do a fuel pump on my brothers truck. Did the exact same thing
Bradbilt is offline
post #7 of 7 (permalink) Old 10-10-2012, 02:58 PM Thread Starter
Etaylor0056
Etaylor's Avatar
Re: HPOP???
Thanks for the Info guys. I'm hoping that its that simple. Glad yall know your stuff.
Etaylor is offline
