slow cranking please help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-09-2012, 12:58 AM Thread Starter
truck has been crankin real week for last month and a half no matter how warm it is, i could drive it for five hours and shut it off then start it right back up and it sounds like its barely gonna start. but when i check the batteries and charging system with a load tester it says everything is good. any ideas? is it possible my starter is goin bad and takin alot more juice to crank it?
94psd5speed is offline
post #2 of 13 (permalink) Old 10-09-2012, 01:18 AM
Re: slow cranking please help
Yeah, if it cranks slow, then starter and/or fender relay are the prime suspects. Try jumping the relay with a jumper cable, see if that makes it crank faster.
madpogue is offline
post #3 of 13 (permalink) Old 10-09-2012, 01:37 AM
old Smokey's Avatar
Yes. It is vary common to have the starter to turn slower when they are going bad. What is the amp draw? Check the connection's at the starter and look at the cable. The connection at the starter on the cable can have corrosion going up the cable. You need a certain cranking rpm on diesel's for good starts. Good luck.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #4 of 13 (permalink) Old 10-09-2012, 03:15 AM
zkurtz
zkurtz's Avatar
If it is the starter, which it more than likely is, upgrade to an 03' 7.3 starter...it cranks way faster, its a 2 bolt mount and you will need to bore out a wire connection though
zkurtz is offline
post #5 of 13 (permalink) Old 10-09-2012, 03:26 AM
Bugman's Avatar
The fender relay is only a control signal relay for the starter solenoid. The actual solenoid for the starter is on the starter and gets its feed directly from the battery and I doubt that you could get any jumper cables on it.
Bugman is offline
post #6 of 13 (permalink) Old 10-09-2012, 05:49 AM
What zkurtz said,
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #7 of 13 (permalink) Old 10-10-2012, 12:28 AM
Ahh, good point; a weak relay would cause a weak signal to the solenoid, which might cause the solenoid to fail to engage, or to "buzz", but indeed, it wouldn't cause the starter motor itself to turn slower.
madpogue is offline
post #8 of 13 (permalink) Old 10-10-2012, 02:31 AM Thread Starter
Thanks for all the input guess I'll throw a starter on it and see what that does
post #9 of 13 (permalink) Old 10-10-2012, 03:33 AM
STILL LEARNING
Bradbilt's Avatar
Did you test the batteries separately?
Bradbilt is offline
post #10 of 13 (permalink) Old 10-10-2012, 06:52 AM
Real Trucks Rattle!
Strokin450's Avatar
Send a message via Yahoo to Strokin450
Starter! Just had this issue. Had both batteries load tested separate like brad said and they were both good. One time it started to crank then froze up, one swift swing of a 2x4 and it fired back up. Replaced with DP starter and cranks amazing. The easiest starter I had ever changed!! 20min
96 F250 ECLB Intercooler Mod, , 3" downpipe--> 4" straight pipe, 1.1 A/R housing, TS TW tunes, Skyjacker all 4 corners, Maximum boost/pyro/trans gauges, Ion wheels/Nitto tires,Banks trans command, TQ and Valve body upgrades, 160k
2008 CRF-450R- It's a HONDA but still wish it was diesel
2006 Honda Rincon 680 mud machine
Strokin450 is offline
