Up pipes..... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-08-2012, 09:24 PM Thread Starter
Up pipes.....
Ok mine are leaking so bad now I don't even get up to 20 psi. So I was wondering if there is cheaper ones for it than the bellowed ones from International. Can't really afford that right now. Also who has done it and what kind of work am I in for? All I can find is one for the SD. Thanks.
97 CCLB, 6 inch lift, 35's, Custom 4 inch Exhaust, custom air intake and TS 6 position
BigWhite97 is offline
post #2 of 5 (permalink) Old 10-08-2012, 09:31 PM
Re: Up pipes.....
im pretty sure I still have the up pipe and collector I took off my truck last year when I did my turbo. I never split them and they never leaked if your interested.
95 f250 ECLB,silver/purple 199k FFD 350/200s, arps, comp 910 shimmed, BTS ZF delete, glowshift EGT,Boost,trans temp,6" aussies,6637, 6.oh IC,dual sd elec fuel. irate T4, S475/96,136k 97 motor. Twin termies
Plans: twin turbs, crowers and fresh rebuild.
rideracelivemx7 is offline
post #3 of 5 (permalink) Old 10-09-2012, 01:58 AM Thread Starter
Re: Up pipes.....
It depends on price. I just got a new job don't have much. Been laid off for a while. That's why I am just trying to find what's cheapest. Also with them leaking does it cause excessive black smoke. And I'm talking like black smoke like an ignorant teen driving there dads diesel. I hate it.
post #4 of 5 (permalink) Old 10-10-2012, 03:12 AM
Re: Up pipes.....
If you can weld or have a buddy that can do some welding for you get a set of bellows from summit and make your own. The bellows only cost aout $70 shipped. I did mine a few weeks ago when I put in a new clutch. Got a lot of good info from this thread. Home made bellowed up pipes
97 F350 CCLB zf5 4x4 PSD,South Bend Clutch, 6637, 10k, E-Fuel, Fast fill, 3"dp to 5" straight pipe, ebpv delete, home made bellowed up pipes
91 F250 ECLB zf5 4x4 IDIT, Flatbed, 93 front clip
88 F350 C&C RCLB zf5 4x4 460 Dually
93 F150 ECSB e4od 4x4 302 7'' lift
76 F150 RCLB c6 4x4 390fe
91F250XLIDI is offline
post #5 of 5 (permalink) Old 10-10-2012, 05:29 AM
Demon Dually
speeddemon31176's Avatar
Re: Up pipes.....
Excessive leaking at the up pipes won't allow the turbo to spool right which will lead to excessive smoke because of unburnt unused fuel.
speeddemon31176 is offline
