Not gettin any fuel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-07-2012, 10:32 PM Thread Starter
19stroker97's Avatar
Not gettin any fuel
Yesterday I replaced the hpop seal that had been leaking for a while, also replaced all the o rings in the hpop except for ipr while I had it out. I put everything back together and went to start it and it would crank but not start. Kept on doing this for a few minutes and still nothing. Started checking everything and high pressure oil lines were getting oil through them and everything else checked out, but fuel bowl won't fill up. Truck didn't have a single problem other than the oil leak before I took it apart. No check engine lights or anything, and can't get to a scanner till tomorrow. Any ideas?
-Tyler-
-97 F-250 rclb, 305/70-16 cooper stt, 6637, PHP Hydra, AB's, e-fuel, sonnax, ebv delete, ccv mod, 3" dp to 6" tip--Sold
-08 Ram 3500 rclb, 6" Fabtech, 325/60-17 Nittos, egr/dpf delete, Efi by Draconian, s&b, 6" mitre
19stroker97 is offline
post #2 of 11 (permalink) Old 10-07-2012, 10:44 PM
Re: Not gettin any fuel
Well I'm guessing you pulled the fuel bowl to gain clearance correct? Didn't by an chance leave the fuel bowl drain open did you? Ask me how I know lol
loudmouth is offline
post #3 of 11 (permalink) Old 10-07-2012, 11:31 PM Thread Starter
Yea the fuel bowl came out, but the drain is closed lol.
-Tyler-
post #4 of 11 (permalink) Old 10-08-2012, 06:26 AM Thread Starter
Took the fuel bowl out again and then tried startin the truck to see why it wasnt filling the bowl up. When i cranked it over it just barely squirted some fuel out, it didnt even really squirt it out, it just kind of poured out a small amount. Time for a new fuel pump?
-Tyler-
post #5 of 11 (permalink) Old 10-08-2012, 07:54 AM
Demon Dually
speeddemon31176's Avatar
yep new pump is in order.
speeddemon31176 is offline
post #6 of 11 (permalink) Old 10-08-2012, 06:42 PM Thread Starter
Is it common for them to just go out without showing any problems like that? Im not really complaining cause this means its time for e fuel but just wondering.
-Tyler-
post #7 of 11 (permalink) Old 10-09-2012, 04:55 AM
Fixing Broken Stuff
toolmangary's Avatar
What do you have for fuel pressure?
1997 F350 4X4 CCLB PSD
2004 Jetta TDI
1970 Roadrunner 383 4sp
1970 Cuda 426 4sp Dana 60
1956 F100
toolmangary is offline
post #8 of 11 (permalink) Old 10-09-2012, 05:30 AM Thread Starter
I assume youre asking what it was when it was running? Not sure I dont have a fuel pressure gauge.
-Tyler-
post #9 of 11 (permalink) Old 10-09-2012, 06:29 AM
Demon Dually
Try switching fuel tanks and see if it the same. It could be an issue that is switching valve or tank related as well.
post #10 of 11 (permalink) Old 10-09-2012, 06:33 AM Thread Starter
Only has front tank. Po said the rear one rusted out and he removed it. The fuel lines are just cut off right where they curve out to go to the tank...
-Tyler-
