water(coolant) in oil , bad oil cooler? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-07-2012, 05:12 PM Thread Starter
1craneguy's Avatar
Smile water(coolant) in oil , bad oil cooler?
97 f250 7.3psd. No real upgrades to speak of. Did some work on it, had a bad crank sensor, ipr was bad , uvch was toast , ipr pig tail crunchy , replaced the glow plugs n injector cups and injector o rings. Had a cracked cup and 2 bad orings. Did the cups without removing the engine . In the process I noticed the oil was really thin and dark. I got the truck running . It's running way better now. Like I said the oil was thin so I drained it n had it analyzed at the CAT dealer. Came back with excessive water(coolant) . No leaks anywhere but my question is can the water and coolant mix because of a bad oil cooler? The oils not like the result of a blown head gaskets . It's really dark and super thin. No codes whatsoever all the lights n buzzers work :) any thoughts guys ?
1craneguy is offline
post #2 of 10 (permalink) Old 10-07-2012, 09:51 PM
vick97psd's Avatar
Re: water(coolant) in oil , bad oil cooler?
Could be oil cooler or o-rings hopefully that is all yours is. Mine started like that then bam the oil looked like latex paint turns out previous owner didnt change coolant or used wrong coolant or straight water when he did change now i have to replace the front cover.
Daily 2002 F-250 Lariat CCSB 4x4 7.3L 356,000. 4" turbo back, DI 6 position, ebpv delete, 6637 intake, ATS stage 2, bellowed up-pipes, inline spin-on trans filter, plate/fin trans cooler, boost, pyro, IAT temp gauges.
Wife's 2000 Excursion Limited 7.3 4x4 straight pipe, CAI, ATS Stage 2, GTP38R, T-500, PHP Hydra, boost, pyro, trans Gauges.
vick97psd is offline
post #3 of 10 (permalink) Old 10-07-2012, 11:20 PM Thread Starter
1craneguy's Avatar
How did you find out the cover was bad?
post #4 of 10 (permalink) Old 10-10-2012, 04:34 AM
vick97psd's Avatar
Replaced the oil cooler and still had a problem so after changing the water, just cause it started leaking as well no relation to the oil. I pressurized the cooling system and noticed a leak down so a buddy of mine told me to remove the hpop reservoir fill the cooling system and pressurize to 16 psi again and look down in between the front cover and block. Sure enough you could see water spraying from behind w/p area pulled the w/p back off and upon very close inspection you could see the crack
post #5 of 10 (permalink) Old 10-10-2012, 04:58 AM
Demon Dually
speeddemon31176's Avatar
That cracked injector cup could have been the cause of coolant in the oil as well.
speeddemon31176 is offline
post #6 of 10 (permalink) Old 10-11-2012, 01:23 AM
<-Friends bike
Never heard that one . The HP pressure Is so much higher than coolant pressure it would be oil in the coolant .. Cracked cups usually cause Fuel in the coolant ...
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
ActionRick is offline
post #7 of 10 (permalink) Old 10-11-2012, 02:02 AM
vick97psd's Avatar
post #8 of 10 (permalink) Old 10-11-2012, 02:46 AM
But what happens after you shut down the engine, and the oil pressure drops to atmospheric, but the coolant is still under pressure from being hot? Could that possibly cause coolant to get into the oil via the injector cups? Still, in that case, you'd expect to see both forms of contamination.
madpogue is offline
post #9 of 10 (permalink) Old 10-11-2012, 04:46 AM Thread Starter
1craneguy's Avatar
Interesting points. I'm gonna do the oil cooler anyways.
post #10 of 10 (permalink) Old 10-11-2012, 07:37 AM
Demon Dually
This is exactly what I meant and I have seen it happen, or I should say it was the only logical explanation to coolant in the oil and once the injector cups were done it didn't do it again.
