No compression - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 10-07-2012, 01:58 AM Thread Starter
No compression
Did a comp test on truck today and one cyl has no comp.Has alot of blow by to. Is it possible to have burned a piston? Just dont make no sense,was not running the truck hard or anything,just normal driving,running 70 on interstate when happened. Hoping someone can shed some light on this. It happened all of s sudden, no sign or anything.
fastmust88 is offline
post #2 of 3 (permalink) Old 10-07-2012, 09:48 AM
Demon Dually
speeddemon31176's Avatar
Re: No compression
Lots of blow by and no compression would indicate a failure of either the piston or rings. How many miles on the truck?
speeddemon31176 is offline
post #3 of 3 (permalink) Old 10-07-2012, 03:33 PM Thread Starter
Re: No compression
Motor itself has about 320,000 on it. I pulled it out at about 287,000 and put rings, bearings,had the injectors rebuilt and had the heads freshened up and have not had one single prob out of it to now.
