SD hpop??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-06-2012, 07:41 PM Thread Starter
SD hpop???
Can I do a super duty hpop in my 97? If so what do I have to get to make the change?
97 obs, gauges, banks turbo, banks intercooler, K&N intake, Airdog Efuel conversion, baby swamps, ts 6 position chip, 4" lift on 315's with 373's
'97powdersmoke is offline
post #2 of 7 (permalink) Old 10-06-2012, 07:57 PM
STILL LEARNING
Bradbilt's Avatar
Re: SD hpop???
IIRC it is a direct bolt in on a 97
Bradbilt is offline
post #3 of 7 (permalink) Old 10-06-2012, 09:07 PM
lindstromjd's Avatar
Re: SD hpop???
Should be a direct bolt in for a 96-97 truck (it's not for a 94-95). Just make sure you get the 17* super duty HPOP, and not another 15*.
1994.5 F350 Dually Crew Cab
7.3 PSD, 220k miles, ZF5 2wd, 3.55 LS
Current mods: T500, Rosewood 160/30's, Hydro-boost, 120v IDM, 6637 Intake
Mods in the works: TS-6 chip, Inter-cooler, 3" intake plenums, GTP38r, MarkFuga E-fuel
... also waiting on some free time and a few final parts for my Dana 60 straight axle swap.
lindstromjd is offline
post #4 of 7 (permalink) Old 10-06-2012, 11:39 PM Thread Starter
Re: SD hpop???
sorry but what is the IIRC? what year hpop should i ask for? or does it really matter? and are all the fittings the same?
post #5 of 7 (permalink) Old 10-07-2012, 12:12 AM
STILL LEARNING
Bradbilt's Avatar
Re: SD hpop???
If I Remember Correctly= IIRC
You would need a late 99-03 to get a 17* pump
Bradbilt is offline
post #6 of 7 (permalink) Old 10-07-2012, 03:26 PM
Ford Pride
Re: SD hpop???
To use the SD hpop you'll have to take the fittings out of your 15 and put in the 17
If you are buying a new 17* hpop then for the money you should buy a T500
Mike 97 SC F-250 6637,Adrenaline HPOP,203*, BTS tunes,stageII 180/80,IC,E-fuel,3" DP,5" from DP to top of flat top of black stacks,trans cooler,shift kit,all lights blacked out. Soon to come is s366 and a built trans
Ford Pride is offline
post #7 of 7 (permalink) Old 10-08-2012, 08:41 PM Thread Starter
Re: SD hpop???
Cool guys, thanks a bunch, I am going with the t 500
