buddy's stranded no start or crank. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 10-06-2012, 04:21 PM Thread Starter
ColeTrain45's Avatar
well my buddy has a obs truck. drove it to the doctor this morning fired up fine this morning. goes to leave the doctor and nothing just clicked. had him try and get a jump maybe a weak battery...nothing. had him tap starter....nothing. had him jump the solenoid...nothing. had him check connections and hs switch and still nothing....he stranded and i'm at work till late so any help can and would be greatly apreiciated. i'm not familair with obs trucks so i'm coming to you guys.
Mike
ColeTrain45 is offline
post #2 of 16 (permalink) Old 10-06-2012, 06:12 PM
biggreen96's Avatar
Re: buddy's stranded no start or crank.
Do any of the lights on dash come on when he turns the key namely wait to start light.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #3 of 16 (permalink) Old 10-06-2012, 06:23 PM Thread Starter
yeah all thats workin he says
post #4 of 16 (permalink) Old 10-06-2012, 06:23 PM
STILL LEARNING
Bradbilt's Avatar
There is a solenoid on the fender AND the starter.
Also, check Voltage with a meter
Bradbilt is offline
post #5 of 16 (permalink) Old 10-06-2012, 07:15 PM
89 Stroker's Avatar
"clicked"
u either got beat the hell out of the starter or get someone to hit it while he tries to start it, this happened on my obs too
come to find out the wires on the started were loose
1989 F350
7.3L PSD
Crew Cab
Long Bed
4x4
6" Lift
37" Military Wranglers
3.88
_________
04 F350
6.0L SD
Crew Cab
Long Bed
4x4
8" Donahoe Suspension Lift
40" Pro-comp X terrain
4.88
89 Stroker is offline
post #6 of 16 (permalink) Old 10-06-2012, 07:24 PM
Jackleg Mechanic
mastrkee's Avatar
Did he try the jump on both batteries, alternately? And then try getting cables on both at once?
Jeff
06 F350 6.0L CCLB AMARILLO 4X4
- SCT Livewire, Quick Tricks Looney tune, XDP Coolant filter, Blue Spring Mod, High Flow Banjo bolts, Warren's 175/30 injectors with upgraded spools, ARP Studs, PowerMax Stag One Turbo, Bilstien 5100's. Banks 4in turbo back Monster exhaust. All necessary internal bulletproofing. High Idle mod
mastrkee is offline
post #7 of 16 (permalink) Old 10-06-2012, 11:14 PM Thread Starter
Over here now. Changed both solenoids. Nothing.
post #8 of 16 (permalink) Old 10-06-2012, 11:57 PM
Click is gonna be one of three issues. one. Battery dead, two, starter bad, three engine locked up.
1997 Ford F250, 7.3, ZF5
Looking for a Ts6 chip, 3" down pipe and 4" exhaust.
Jon7.3 is offline
post #9 of 16 (permalink) Old 10-06-2012, 11:58 PM
Is it Auto or standard?
Jon7.3 is offline
post #10 of 16 (permalink) Old 10-07-2012, 12:04 AM Thread Starter
Auto
