Brakes seem soft and sometimes work better with a few pumps - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-06-2012, 02:25 AM Thread Starter
Coueshunter's Avatar
My brakes seem soft sometimes and after 2-3 pumps get a bit firmer.
any ideas?
Back the Blue BUILD THREAD
POWERSTROKENATION-
Facebook-
Coueshunter is offline
post #2 of 13 (permalink) Old 10-06-2012, 02:28 AM
Juniorssrollin's Avatar
When's the last time your truck has seen fresh brake fuid? I bet a good bleed will help them tons
Sent from my DROID RAZR using AutoGuide App
2005 CCLB FX4- studded, blue spring, 6.4 banjo bolts, 6 inch lift and 35" Nittos
Juniorssrollin is offline
post #3 of 13 (permalink) Old 10-06-2012, 08:18 AM
Demon Dually
speeddemon31176's Avatar
Re: Brakes seem soft and sometimes work better with a few pumps
speeddemon31176 is offline
post #4 of 13 (permalink) Old 10-06-2012, 09:11 AM
Try and suck out 98% of old fluid in reservoir and replace with fresh before bleeding. Makes it go a little quicker.
post #5 of 13 (permalink) Old 10-06-2012, 04:18 PM
1 Slo PoMoFo
Ranger50's Avatar
Typically, air and never changed fluid lead to sponginess. If new fluid and a good bleed doesn't fix/help it, you are most likely looking at a master cylinder/booster problem.
"Never trust an intelligent man with no money to play fair."
97 F250. 213k. Just about as stock as stock can be. Cali mod. Yard ornament.
Ranger50 is offline
post #6 of 13 (permalink) Old 10-08-2012, 04:16 PM Thread Starter
Brake fluid is all new. First thing I do when I buy a vehicle. Change all fluids
POWERSTROKENATION-
Facebook-
post #7 of 13 (permalink) Old 10-08-2012, 05:37 PM
Maybe vacuum pump getting weak or booster???
'97 F-250 Supercab, 4x4, Dana 60 swap, Intake, IDM Mod, TW 6 pos chip, FS2500 Oil By-pass, Turbo back exhaust, RSK w/ SD springs, 1.0 compressor housing, EBPV delete, Pedestal Mod, E-Fuel with "Tight-wad" regulator mod, HPO-X line, Hydroboost w/ Redhead steering box
Hijo202 is offline
post #8 of 13 (permalink) Old 10-08-2012, 11:46 PM
If it's weak then the brakes would be too firm.
If you just bled them, there is still air in the system or the rubber brake hoses are bulging.
How did you bleed them?
Use a vacuum or pressure bleeder?
1997 F250 05+ Axle Swap 3.73 Home Built 4-link Front with Ballistic Parts. 2.5" Front Coils. B-code Rear. DIY Trans w/ Precision COnverter. DIY Traction Bars. TDP 6-Pos Chip BW TP38 w/ 1.00 EXH. Rosewood DIY STG1's. DIY E-Fuel w/ Dual FM100's. SD quad pod above Rearview
turboaz2 is offline
post #9 of 13 (permalink) Old 10-09-2012, 05:30 PM
any ideas?
I almost bet if you put a T in you vacuum line so you could put a vacuum gauge (which would provide great brake pressure assistance) on it you would see good vacuum for the first pump then it would drop each pump in succession afterwards (less vacuum the firmer they feel from less assistance) because the pump can't keep up. One of reasons I went to hydroboost.
96 F250 CCSB 4x4, D60, 3.55, Auto, 6.0 trans cooler 3"-4" down pipe & exhaust, not enough power
wildstang is offline
post #10 of 13 (permalink) Old 10-10-2012, 03:43 AM
rolsmojave3's Avatar
Adjust rear brakes.
97' F-350 7.3 5 speed, 160cc Rosewoods, 315/75r16s 16x10 MT fakelocks
96' F-350 7.5 5 speed, cali truck, 315/75r16s on Alcoas
02 Ranger FX4
79 "F350" mud truck, 18.5/44-16.5s
rolsmojave3 is offline
