Brakes Problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-05-2012, 10:12 PM Thread Starter
BlackOut96's Avatar
Brakes Problem
Well I was driving my truck back from lunch today and my brake pedal got really stiff and i had to put a decent amount of pressure on it to get it to stop. I also noticed lately that sometimes my abs light stays on for longer than normal and also sometimes coming to a stop my rear brakes would lock up. Not sure if the second part is really part of my problems but i dunno. Any ideas what it could be?
2004 Ford F350 6.0 6 speed 4x4, Silver Supercab Longbed, Afe stage 2 CAI, straight pipe exhaust, leveled on 35s, Sinister Diesel coolant filter system, 288k miles
"Sorry officer I thought you wanted to race." - Anonymous
BlackOut96 is offline
post #2 of 5 (permalink) Old 10-05-2012, 10:18 PM
zilla68's Avatar
Re: Brakes Problem
vacuum pump is either going out or gone out, better act quick or you'll be walking cause it will leave you stranded.
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #3 of 5 (permalink) Old 10-05-2012, 10:25 PM Thread Starter
BlackOut96's Avatar
Re: Brakes Problem
well whats wierd is that my ac works and my vaccum pump makes no noise
post #4 of 5 (permalink) Old 10-06-2012, 01:16 AM
biggreen96's Avatar
Re: Brakes Problem
I agree vaccum pump is going out. It is still making enough vaccum to run controls but not to help with braking.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #5 of 5 (permalink) Old 10-06-2012, 08:19 AM
Demon Dually
speeddemon31176's Avatar
Re: Brakes Problem
Vacuum pump is failing. Replace it before you have bigger issues.
speeddemon31176 is offline
