how to remove front rotor from hub? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 10-05-2012, 02:16 AM Thread Starter
StrokinSince97's Avatar
So I've got a 97 F250HD with the Dana 50 I pulled the rotor and hub off together but cannot get them apart. My new rotors dont have studs for the wheel nuts so im guessing they pull apart and the new rotors connect to the hub. How do you do this? Do i have to have the old rotors pressed off and the new ones pressed on ?
StrokinSince97 is offline
post #2 of 5 (permalink) Old 10-05-2012, 02:37 AM
Here for the Ride!
devinferg's Avatar
Send a message via MSN to devinferg
Re: how to remove front rotor from hub?
As for the wheel studs take a lug nut and put on each stud until flush with top of stud then take a hammer and drive them out, after that put them in new rotor and use an air impact to drive nut down on stud to press it into the new rotor. No special tools required. As for the hub from rotor you can see a split between them if take a chisel or punch and drive it in between them. You will have to do some serious beating to get them spit apart if they havent been off in awhile but it should come apart some what easily with a 2 pound sledge hammer. Hope that helps
1997 F350 Reg cab-Powerstroke 5 Spd 135k miles ts 6 pos chip diy k&n intake 4 inch exhaust autometer gs series pyro & boost gauges-SOLD
2001 F350 Reg cab- 7.3 powerstroke 157k miles Wicked Wheel 6 pos chip Full ATS transmission and 5 star converter 5" exhaust DIY traction bars ISSPRO gauges pyro boost and trans temp
devinferg is offline
post #3 of 5 (permalink) Old 10-05-2012, 04:07 AM
psdmike's Avatar
unless you have a press that's the way to do it. Get the lugs out and split it apart.
1997 F350 Crew Cab, 7.3, 4x4, 5SP Short Shift kit, 5" RSK SD V Code springs, DIY Intake, 5" Exhaust with 30" FTE Resinator, intercooled, TS chip.
psdmike is offline
post #4 of 5 (permalink) Old 10-05-2012, 02:08 PM
If things are rusy copious amounts of Pb blaster will work wonders. Oh and read the instructions on the can. Good Luck
ToddM715 is offline
post #5 of 5 (permalink) Old 10-05-2012, 02:52 PM
MB97PSD's Avatar
Make sure you anti-sieze the hub and rotor mating surfaces, and the wheel studs, when you put it back together. Makes easier in case you are the next SOB that has to do it the next time.
Matt
97 F350 Reg Cab 4x4 PSD/E4OD
87 F250 Reg Cab 4x4 6.9/C-6
MB97PSD is offline
