cluch box upgrade? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 10-04-2012, 06:28 AM Thread Starter
cluch box upgrade?
The Guy I bought my truck said he installed a south bend stage 3 clutch. Idk if it is or isn't all I know is IV got problems with my clutch box flexing to the point where its hard to get in gear.....I have been told there is a reinforced clutch box. I have searched high and low and can't find one.
Have I been told wrong?
97 f350 cclb 4x4 310k zf5
south bend clutch,banks IC, header wraped ic pipes,banks .82 exhaust housing ,TS 6pos,S&B cold air intake
project truck is a 77 f250 crewcab on a 88f250 frame, 4x4 7.3 idi zf5 IP turned up and tuned
other project truck 78 f350 crewcab 4x4x4 4.9L turbocharged zf5 monster truck
poorboy's stroker is offline
post #2 of 16 (permalink) Old 10-04-2012, 01:06 PM
OBS Stroker
Nodge's Avatar
Re: cluch box upgrade?
Check your rod bushing under the dash and the plastic bushings in the pedal assembly.
I don't know what you mean by a clutch box.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #3 of 16 (permalink) Old 10-04-2012, 01:37 PM
^^^^^ +1; bushing on the pushrod eyelet, and/or the eyelet is expanded by wear, and/or weak hydraulics, and/or pedal box bushings.
Is it also hard to get the pedal down enough to get the starter to kick in?
madpogue is offline
post #4 of 16 (permalink) Old 10-04-2012, 02:06 PM
STILL LEARNING
Bradbilt's Avatar
You heard wrong, no reenforced clutch box. Just put new plastic bushings in they will go another 100k
Bradbilt is offline
post #5 of 16 (permalink) Old 10-04-2012, 03:38 PM
Patrick Feeley's Avatar
IIRC, I think there was a reinforcement plate for the firewall (maybe in a TSB), but I'd have to look around some more. Cheers!
Patrick Feeley is offline
post #6 of 16 (permalink) Old 10-04-2012, 05:00 PM
STILL LEARNING
Bradbilt's Avatar
They had those for the 1980-91s
Bradbilt is offline
post #7 of 16 (permalink) Old 10-04-2012, 05:10 PM
Thanks for clarifying that. Cheers!
post #8 of 16 (permalink) Old 10-04-2012, 10:24 PM Thread Starter
Its not the bushing or push rod....there fine....the bracket that hold the clutch peddle is flexing.
post #9 of 16 (permalink) Old 10-04-2012, 10:35 PM
That's probably the bushings (there's a set of four) in the pedal box, for the cross-shaft that goes between the pedal and the arm. You have to remove the pedal box to replace them, and that would be your opportunity to inspect it, to see if the box itself is damaged in some way that's making it flex (it may have a crack or something).
madpogue is offline
post #10 of 16 (permalink) Old 10-04-2012, 11:37 PM Thread Starter
To remove it. Undo the clutch push rod brake push rod and 2 bolts holding the box right?
And are the clutch box's prone to cracking?
I'm assuming mines factory so its got 310k on it and I'm also assuming the pressure plate is heavier then stock.
