'96 Powerstroke upgrade help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 10-04-2012, 01:24 AM Thread Starter
I have a 1996 Powerstroke and until I can put some real money into it after I get out of the Army, I wanna know if there's any relatively cheap and easy upgrades I can do to it to gain just a little more power/ maybe make it smoke a little. It's got 274K on it and a 6in lift that's turned into a 4in (the retard before me had leaf springs that are basically flat). The exhaust is already straight piped. Any tips?
Superstroke1996 is offline
post #2 of 11 (permalink) Old 10-04-2012, 01:54 AM
Re: '96 Powerstroke upgrade help
Fpr shim,idm mod, 6637, downpipe
97 f250 eclb e4od 4x4: p.i.s. 175/80s, built trans, obs/e99 hybrid turbo, t500, .20 over, afe intake, afe 4" straight pipe, comp springs, efuel, sd intercooler, isspro gauges, superchip 1705 because I can't decide between tony wild man or gear head for tunes....
blacksmoke powerstroke is offline
post #3 of 11 (permalink) Old 10-04-2012, 04:05 AM
LBZ
LBZ's Avatar
Umm what? ^^^^^ More details links if possible.
I'm in the same boat except already have the dp with MBRP exhaust.
'07 Duramax
'97 Powerstroke
LBZ is offline
post #4 of 11 (permalink) Old 10-04-2012, 06:52 AM
Fuel Pressure Regulator, Injector Drive Module. 6637 (napa part#) is a huge air filter to replace the stock air box. It's a do it yourself thing. Down pipe is on the exhaust side of the turbo it's that almost flat thing coming off the turbo. Use the search feature you can find all this stuff that way. Oh and FYI looking for more smoke around here is prolly gonna get you a little harassment. It's just wasted fuel, it's a PS not a cummins. Welcome and good luck!
Sent from my Autoguide iPhone app
1995 CCLB SRW Auto- sold
2008 job#3 F-350 CCLB SRW 4x4
95onetonRigRide is offline
post #5 of 11 (permalink) Old 10-05-2012, 05:30 AM
Terminator Nation
FPR mod is using a BB to shim the fuel pressure regulator spring to increase average fuel pressure. It raises fuel pressure from about 50-55 psi to about 65 psi.
IDM mod is changing one resistor to raise the injector drive voltage from about 100 volts to about 140 volts for a slightly faster injector opening event. about 5 cents for the resistor, about $100 if you have someone else change the resistor.
Use a NAPA 6637 filter element, a 4" 45* exhaust pipe elbow and two 4" clamps for increased air flow and better filtration when changed out for the stock stuff.
Changing out the stock flattened downpipe for a 3" diameter downpipe with no other exhaust mods will still give you a performance increase and reduced EGTs.
old man dave is offline
post #6 of 11 (permalink) Old 10-05-2012, 06:42 AM
OBS Stroker
Nodge's Avatar
Originally Posted by Superstroke1996 View Post
(the retard before me had leaf springs that are basically flat). Any tips?
F250 or 350?
250 springs pretty much run flat or even a negative arch if they are old.
It's not that retread's fault that ford put a ttb axle in the f250.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #7 of 11 (permalink) Old 10-05-2012, 12:47 PM
LBZ
LBZ's Avatar
Thanks for the breakdown!!
Any negative's from upping the IDM drive voltage? Does it cause anything to burn out faster? What is the end result of opening the injector faster?
'07 Duramax
'97 Powerstroke
LBZ is offline
post #8 of 11 (permalink) Old 10-05-2012, 02:31 PM
ntruderrider's Avatar
Originally Posted by Nodge View Post
F250 or 350?
Sorry for the numbnut ?, but what is a "ttb" axle?
ntruderrider is offline
post #9 of 11 (permalink) Old 10-05-2012, 02:41 PM
zilla68's Avatar
twin traction beam=ttb
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #10 of 11 (permalink) Old 10-05-2012, 06:51 PM
Lots of mods available performance and suspension...
Always std basics first:
Tymar
Guages
turbo back exhaust
Then:
TS chip with custom tunes..TW
Boost fooler
SD IDM, $5 resistor mod or Beans exchange IDM
Then its sky the limit...mods dependent on HP needed and budget.
suspension...RS kits and SD springs with stock D60 to '04 axles or '05 up axles and 4 link kits.
If I can help let me know.
Cary
email:
Website:
OBSWIZ is offline
