Time for an injector rebuild and process - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 10-03-2012, 02:32 PM Thread Starter
nossliw's Avatar
Another question for you all. I have 3 trucks my boss asked me to pull and do all 8 injectors on. I plan on doing my own as well. These are fleet trucks and we are just going to go with premium rebuilds from rosewood. I plan on doing 1.5's for mine.
The reason we are doing this these few trucks have a sticky injector issue. We have taken them to a very respectable diesel shop here in CO, and were told the injectors are sticking untill the motor warms up, He has told us the same thing multiple times and he thinks its time for injectors due to the tests done on the injectors.(Front Range Diesel) I'm sure there are many of you who have experienced this... especially in colder states. The issue has continually gotten worse over the last couple years on two of the trucks. The truck will run on 7 out of 8 cylinders untill it warms up a bit and then it runs excellent. Its like a switch flicks and your back to normal. Happens every morning with mine within the first 2 miles leaving the house. Hold your glow plug and relay/vc gasket comments. All our trucks have brand new OE Motorcraft GPs and VC gaskets w stancore relays.
One of the specific trucks sounds like its almost 3 cylinders down when cold. Its almost impossible to start in the cold, and typically takes a consistent jump to keep the batteries in check from cranking and cycling the glow plugs. It is much easier to start when plugged in but still is a bear to get running. Blows white diesel when cold too. Compression test on all three are well within spec when warm, and the smoke is diesel not oil. It will warm up after idling horribly rough and once warm it idles perfect, and it tows like a bat out of hell all day. Pretty sure they are the factory stock injectors at around 220k.
Anyways I will be pulling them and sending them to Jim at Rosewood. I have never done business with him, but from the sounds of it he does top notch work. I personally have never done injectors on these trucks and was hoping you all could point me in the right direction to a thread that has pics and steps for removal of the injectors. I have done glow plugs on all them, and that was easy enough, just have not done injectors.
I wanted to check with you all who have experienced this problem what the solution was for you. With brand new batteries, starter, and oil change the truck experiences the same issue. The GP system is brand new which really points me to injectors... It runs great after a half hour of hard idling to bring the motor up to temp and then the injectors free up and it idles smooth and run like its a 100 degree day out. Like I said he is not sure if the injectors are stock from the factory or not, but I have a feeling they are. I'm not really sure how to tell either.
So in resolution:
1. I need a link to detailed threads on how to replace injectors... I heard you can hydro lock and bend a rod, and will be in deep #### if this happens!
2. Any advice on what else it may be before I send them off... He will loose his #### if I charge him for a set of injectors and the truck still won't start and idle on a cold morning, even when plugged in. I'm only doing one truck at a time.
Thanks in advance!
96 F250 CCSB, D60 SAS, 460, E40D, 3:55's, D-Thorleys
Sold the supercharged 547, 12V cummins twin swap in process
97 SCLB 7.3 PSD ZF5, 4:10'S, DP tuner, 6637, 4" Straight, EBPV delete, CCV delete, 3" plenums w 6.0 IC/ Rosewood stage 1's/waterinjection/ T500 ARPs, springs, rods and a 366 in process
nossliw is offline
post #2 of 14 (permalink) Old 10-03-2012, 09:31 PM
Patrick Feeley's Avatar
Re: Time for an injector rebuild and process
Just what I do when R&R'ing injectors:
Once the injectors are out, I like to suck all the fluid out of each cylinder with a mightyvac. Then, once the injectors are installed and glowplugs are out, I will place the valvecovers in position and spin the engine over by hand a few revolutions (wrench on crank bolt). After that, you should not have any hydrolocking issues. Some folks will say that is overkill (some just put the VC's in place and spin the engine with GP's out using the starter without sucking anything out), but I'd rather take the extra time and not risk it. Cheers!
Patrick Feeley is offline
post #3 of 14 (permalink) Old 10-05-2012, 05:43 AM
Terminator Nation
After turning the engine over by hand, crank it over with the starter without installing the glowplugs or plugging in the injectors. Do this for about 10-15 seconds then cool down for about 5 minutes repeat 3-4 times. The engine will crank over at a very high speed purging a lot of air out of the oil gallerys, blowing out any residual oil out of the cylinders and does not flatten out the batterys. Then reinstall the glowplugs/ plug in the injectors. The engine will fire up very quickly.
Once you loosen the injector clamp, I use a Vaughn SuperBar to pry out the injector from the intake side of the head.
old man dave is offline
post #4 of 14 (permalink) Old 10-08-2012, 03:59 AM
Please keep us informed how this turns out. I have a similar issue I have been fighting for years. I have rebuilt my injectors (DIY stage I's) but never replaced them.
97 F350 CCLB 4X4 DIY Stage I's, Beans D66 Turbo, SD CAC, Tymar Filter, T-500 HPOP
JMCX is offline
post #5 of 14 (permalink) Old 10-08-2012, 04:22 AM
Swamped
Look here
http://www.swampsdiesel.com/files/7....Diagnostic.pdf
And here
http://www.swampsdiesel.com/site/ins...stallation.pdf
2012 F350 6.7 Lariat - Stock for now
1999 F250 7.3 Lariat - Up for sale soon
chris1978 is offline
post #6 of 14 (permalink) Old 11-13-2012, 02:22 AM
Any update on how this worked out?
JMCX is offline
post #7 of 14 (permalink) Old 11-13-2012, 03:27 AM
Addicted Offroad
AddictedOffroad's Avatar
Very thorough write-up
How To: 7.3L Powerstroke Injector Removal and Installation
Scotty
Addicted Offroad
1994.5 F350 CC, DRW, ZF5, 2WD. Valair Clutch, Stage 1's, T-500, 6637, 7.3L Intercooler, 3" to 4" Diamond Eye, PHP Hydra Chip.
AddictedOffroad is offline
post #8 of 14 (permalink) Old 11-13-2012, 03:23 PM Thread Starter
nossliw's Avatar
I will let you all know in about 3 weeks when its its finished... I have to wait 2 weeks till December till we can pull thr truck off the fleet.
nossliw is offline
post #9 of 14 (permalink) Old 11-13-2012, 03:33 PM Thread Starter
nossliw's Avatar
Thanks for the links!!!
nossliw is offline
post #10 of 14 (permalink) Old 11-25-2012, 04:01 AM Thread Starter
nossliw's Avatar
Well just a little update...
Started the first fleet truck today, took about 4 hours to get everything out and tested before removal. Fairly simple job needless to say. Motor is purged and ready for the new sticks. Calling Jim on Monday and will order the stock sticks for the fleet truck, and then stage 1's for my truck.
My personal truck has been progressively worse. More oil consumption, wont start when its below 35. Fires right up without injectors sticking when its plugges in for 1-2 hours...
Anyways I'll update this thread as time goes on... was really hoping to get 6 more weeks out of my injectors but if we get a winter that isn't abnormally warm, then I'll be SOL at the lot on my way home from work.
nossliw is offline
