High beam light and headlights on after shutdown? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 10-03-2012, 06:10 AM Thread Starter
Hey Guys riddle me this one?
After extended idle 2 hours or so, shut truck off got out messed about (work stuff) looked back at truck and high beams are on. I look on the dash and switch is in (read light switch off), notice on dash that the high beam indicator is on? Pull headlight switch all the way out then all way in... Highbeam indicator still on. Fire up truck cycle headlight switch shut off engine lights finally go out. Never have ever had this happen, only thing I can think is the extended idle time was not liked by the Day Time Light running modul?
Any suggestions?
Thanks in advance,
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
post #2 of 8 (permalink) Old 10-03-2012, 06:47 AM
Demon Dually
speeddemon31176's Avatar
Re: High beam light and headlights on after shutdown?
Sounds like the DRL module suffered some sort of fault internally that kept the lights on. Has it done this since then or is it a one time event?
speeddemon31176 is offline
post #3 of 8 (permalink) Old 10-03-2012, 08:09 AM Thread Starter
So far one time event.
JCart is offline
post #4 of 8 (permalink) Old 10-03-2012, 11:59 PM
Or the "flash-to-pass" contacts in the column stalk were somehow closed.
madpogue is offline
post #5 of 8 (permalink) Old 10-05-2012, 05:35 AM
Terminator Nation
This sounds like the most plausible scenario. A problem with the DRL stuff should be low beam only, I think.
old man dave is offline
post #6 of 8 (permalink) Old 10-05-2012, 07:01 PM Thread Starter
Hey Dave, I always thought the DRL where based on 1/4 power running through the Hi beam circuit?
Has not happened since... but will be more attentive when if happens next time.
jrc
JCart is offline
post #7 of 8 (permalink) Old 10-06-2012, 08:10 AM
Demon Dually
The DRL is the high beam circuit and not the low beam circuit. It does operate at a reduced voltage from the normal high beam setting. If the flash to pass contacts were connected then you would have seen the high beams on at full power. That would be the best way to determine if it was the flash to pass or the DRL causing the issue.
post #8 of 8 (permalink) Old 10-06-2012, 03:46 PM Thread Starter
Thanx Speeddemond
JCart is offline
