ANOTHER no start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 10-03-2012, 03:05 AM Thread Starter
STILL LEARNING
Bradbilt's Avatar
ANOTHER no start
Well I dropped my truck of at the window tint shop the other day. Tinter called today and says tint is done BUT truck stalled in garage and will not start.
Quick ran over with scanner to check RPM. Fuel pressure etc. BUT the scanner is saying no communication. It is a snap-on 2500 and it DID work on this truck.
NOW, I was fixing a cigaret ligher wiring issue on sunday before I dropped truck of, so I dont know if I blew the fuse. What Number and amp is that?
Also, what pin in the OBD connector is 12v for the scanner? (From left to right and top or bottom row)
Also, what amp is Fuse #22?
And What plug on the fuel bowl is for the heater?
Sorry for all the questions, but I want to get the truck out of the tinters driveway
Bradbilt is offline
post #2 of 19 (permalink) Old 10-03-2012, 04:35 AM
Bugman's Avatar
Re: ANOTHER no start
The fuse for the Data Link is #16 and it is a 15 amp fuse in the cab, top right hand side.
OBD hot pin is pin 16 on the connector, lower right hand side.
Fuse #22 is a 20 amp maxi under the hood
And here are a couple of pictures, one of the fuel filter bowl and a pdf of the Data Connector.
Bugman is offline
post #3 of 19 (permalink) Old 10-03-2012, 01:28 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
THANK YOU Bugman
Bradbilt is offline
post #4 of 19 (permalink) Old 10-03-2012, 04:12 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Well, All fuses are good and I have power to the OBD port. Still no scanner communication.
What else should I try?
Bradbilt is offline
post #5 of 19 (permalink) Old 10-03-2012, 05:41 PM
Bugman's Avatar
Sounds like you need to swap out the PCM. Or check the power and pin posistions on the PCM.
How is fuse #9 under the hood that feeds the PCM?
Bugman is offline
post #6 of 19 (permalink) Old 10-03-2012, 05:55 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
I'll have to look at that. Gonna trailer it back home to make it easier to work on
Bradbilt is offline
post #7 of 19 (permalink) Old 10-03-2012, 08:37 PM
Just to double back, do you know anyone else with an OBS PSD, that you can try the scanner on their truck? Just in case something did happen with the scanner in the interim. IIRC, it needs the K2 vehicle-specific "key", right? Maybe the brick itself is okay, but something happened with the key.
madpogue is offline
post #8 of 19 (permalink) Old 10-03-2012, 08:39 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Yup. K2. I thought same thing. Plugged it into my ranger and it communicates
Bradbilt is offline
post #9 of 19 (permalink) Old 10-03-2012, 10:57 PM
But your Ranger is more forgiving; it'll communicate with anything that speaks OBD-II. To be sure, you need to try to talk to another OBS PSD. It's unlikely that's the problem, and of course is unrelated to the no-start, but you also don't want to be chasing your tail over a comm issue.
Truck doesn't have a chip, does it?
madpogue is offline
post #10 of 19 (permalink) Old 10-03-2012, 11:11 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Does have a chip and when the scanner is plugged in, the chip numbers keep rotating thru like when you 1st start the truck(dp tuner)
Bradbilt is offline
