i need help pls - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 10-02-2012, 10:32 PM Thread Starter
i need help pls
what i have is a 97 f350 psd with a ZF5 310K on it
it has a banks IC/pipes, S&B cold air, new remaned stock injector 3K on them, banks .82 exh housing, TS 6pos tuner,and new map
i have had it 3 months now and have replaced injector O rings, fuel filter oil filter, rebuilt the turbo and replaces the stock exh housing with the .82.
my problem is at 3200 and 3400rpm i have a miss,and pure white smoke. when it misses my injestion psi goes fron 3200psi smooth to unstedy 2700-2800psi. it will only do it with a when driving. and only in 3 and 4th gear. im guessing 1 and 2nd go by that rpm range to fast. it also at this rpm range i am making max boost of 24psi. when it misses i can see my boost spike down to about 15psi. witch leads me to believe its caused by blowby on the rings.
but with it running and the oil filler cap off there is vary little smoke coming from it.. ihave not mesured my blowby yet.
its not throwing any codes its getting about 12-13mpg highest egt iv hade was 1000*
im looking at cleaning/rebuilding my IPR this weekend just to make sure its not that causing my problems.
i have searched for some time now on this site and cant find any one with the same problem. if you have a post i will be more then gladly to read through it if it will fix my truck.
poorboy's stroker is offline
post #2 of 6 (permalink) Old 10-02-2012, 10:36 PM Thread Starter
Re: i need help pls
i have also tryed all the setting on my TS, removed my TS and tryed a diffrent PCM. all have the same problem at the same RPM range
post #3 of 6 (permalink) Old 10-03-2012, 12:08 AM Thread Starter
Re: i need help pls
i have also checked my fuel psi and it stedy at 60-65 psi wot 45psi at idle.... that after the filter
post #4 of 6 (permalink) Old 10-03-2012, 06:51 AM
Demon Dually
speeddemon31176's Avatar
Re: i need help pls
Could be the hpop is weak, the IPR is malfunctioning, the ICP is faulty, one of the reman injectors is faulty, injector o-ring suffering a leak with psi that high, turbo is acting up, etc. Get it on a scanner and watch live data to see what everything is doing when this happens.
speeddemon31176 is offline
post #5 of 6 (permalink) Old 10-03-2012, 10:18 PM Thread Starter
Re: i need help pls
i replaced the Oring less the 500miles ago. and i installed them by lubing the orings well, gently pushing while twisting them till they were seated.
i had it on a scanner and watched the injection psi thats how iknow what psi i maxed at was and what it drops to when it misses...what else should i be looking at on the scanner?
i plan to pull the IPR this weekend and clean it out.
i was looking at upgreading my HPOP soon.as well
97 f350 cclb 4x4 310k zf5
south bend clutch,banks IC, header wraped ic pipes,banks .82 exhaust housing ,TS 6pos,S&B cold air intake
project truck is a 77 f250 crewcab on a 88f250 frame, 4x4 7.3 idi zf5 IP turned up and tuned
other project truck 78 f350 crewcab 4x4x4 4.9L turbocharged zf5 monster truck
post #6 of 6 (permalink) Old 10-05-2012, 05:25 AM
Demon Dually
Re: i need help pls
You will want to know what the IPR and ICP are doing at that time when the rpm's are that high. If you are maxed out then it could be a sign of a failing hpop or you could be seeing a bad IPR or leaky/faulty ICP.
