Depressurize Fuel System - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 10-02-2012, 05:59 PM Thread Starter
Shovel's Avatar
I converted to electronic fuel and need to adjust the length of my already connected feed line. I figured that disconnecting the electrical to the pump would depressurize the line, but somehow the engine was able to start up multiple times and run like a pump was never needed even though the regulator reads 0 psi.
With that said, here are my dumb questions:
How is that possible?
How do you properly depressurize an electronic fuel system?
Once depressurized, how can i rid of excess fuel in the lines so that I don't dump half a gallon on my face?
Shovel is offline
post #2 of 7 (permalink) Old 10-02-2012, 06:09 PM
sharpmotors's Avatar
Re: Depressurize Fuel System
there is no pressure if the pump is not running you only have the fuel that is in the line.just unhook the the line from what ever end you want to shorten it and let it run into a bucket or pail.
1997 f350 xlt regular cab 4x4,matercraft courser at2 285's, automatic,1.0 housing,ebpv delete housing and pedestal,tymar intake,diamond eye dp w/4 inch straight pipe,super duty starter,203* tstat
sharpmotors is offline
post #3 of 7 (permalink) Old 10-02-2012, 06:29 PM Thread Starter
Shovel's Avatar
Last time i did that fuel poured out the lines all over the place and was hoping to avoid that because it's going to be hard enough to get the hose off. Oh well, I'll give it another whirl. Thanks.
Shovel is offline
post #4 of 7 (permalink) Old 10-02-2012, 07:03 PM
csp
Clamp a pair of vice grips on the line you're going to shorten to keep it from running all over the place.
csp is offline
post #5 of 7 (permalink) Old 10-02-2012, 09:18 PM Thread Starter
Shovel's Avatar
Hmmm, simple and fairly obvious solution.... that I always seem to overlook.
Thanks!
Shovel is offline
post #6 of 7 (permalink) Old 10-02-2012, 11:47 PM
The 7.3's injectors can act like little pumps and still allow the pump to run even if there is no pressure in the fuel system. They'll essentially create a vacuum and pull fuel up from the tank. They'll idle all day, but won't do much more than that.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 215k miles: FFD 250/200%'s, Swamps IDM, built trans, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube, Homemade e-fuel/intake/exhaust/traction bars, D66, Built and tuned by me
97 ECSB F-250 project truck. Current plans: 7.3, BTS, 250/2's, 468, stock bottom end
JD3020 is offline
post #7 of 7 (permalink) Old 10-03-2012, 12:37 AM Thread Starter
Shovel's Avatar
Good to know. I bet my fuel pump had been toast for a while then.
Shovel is offline
