did i do okay buying my firstpowerstroke? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 10-02-2012, 10:16 AM Thread Starter
hey guys i bought a 1996 f-250 extended cab short bed 4x4 powerstroke 5 speed. for 3k I live in pennsylvania so it does have a little rust here and there but compared to most up this way its pretty solid. (just needs fenders in front and wheel wells in the bed) but here is list of some of the upgrades the truck has.
-Dana 60 front
-aftermarket air intake with open element
-bully dog propane injection
-50hp chip
-reprogrammed idm (i think he said it was but don't hold me to it something he reprogrammed to get more power)
- took auto out and installed zf 5 speed
-luk single mass flywheel
-one ton lief springs whole way around
-3 inch downpipe into 3.5 strait pipe
-ford lightning speedometer that goes up to 120mph
the interior looks like new still and truck looks like it was well taken care of the truck has 150k miles on it but supposed to have less then 100k miles on motor and trans. One thing i noticed is after the wait to start light goes out and i go to crank it over it takes about 6sec of cranking and give it a little fuel and then it will fire up in (50 degree weather)
please let me know what you guys input is.
Bignbadbelair is offline
post #2 of 12 (permalink) Old 10-02-2012, 10:57 AM
OBS F350's Avatar
Re: did i do okay buying my firstpowerstroke?
Sounds like you got a great deal! The starting issue could be the glow plugs, I would try jumping the glow plug relay (just a regular solenoid) before you go to start it jump the glow plug relay for about 10 seconds and see if that helps it start. If it does replace the relay, if not I would look into it a little further. That relay seems to be a common problem, but diagnosing a hard starting issue is a little more work due to the injectors being fired off of high pressure oil.
If you are looking for more power I would look into a TS 6 position chip tuned by one of the vendors here, a few good ones are Tony Wildman, Matt @ Gearhead automotive, swamps, beans, etc. Ditch the propane injection, if set up incorrectly it can cause major problems. Depending on your financial situation I would look at getting your injectors built, Jim @ Rosewood is awesome and his prices are very fair! 160cc is a very good injector for a relatively stock truck.
96 F350 zf-5, Rosewoods, 6637, mbrp, southbend, autometer, Rough Country. SOLD
08 f250 auto, dpf/egr delete, afe intake, Gearhead tunes
:, cold side pipe and cfm+ intake elbow.
OBS F350 is offline
post #3 of 12 (permalink) Old 10-02-2012, 02:07 PM
STILL LEARNING
Bradbilt's Avatar
You did fine. But If I remember Correctly, the supercab short beds only came with 5 speeds. I had a hard time finding one, so I opted for my crew cab
Bradbilt is offline
post #4 of 12 (permalink) Old 10-02-2012, 02:59 PM
csp
No they didn't.
You remember correctly. I couldn't even order one with an auto when I bought mine in 97. Some BS story about the wheelbase being too short, even though it was longer than the regular cab longbed, which you could get an auto in.
csp is offline
post #5 of 12 (permalink) Old 10-02-2012, 03:04 PM
look what i can do
1badpsd's Avatar
Yea as said before ditch the propane asap.
1badpsd is offline
post #6 of 12 (permalink) Old 10-02-2012, 04:26 PM
03fathead6.0's Avatar
Bump for Jim @ Rosewood great guy and realy fair prices...
2003 F250 6.0, 4" on Pro Comp 35's, Twin Grand rock 6" mitre cuts set to 2" above cab, Dyno Mat cab, SCT X4, Blue spring, CCV mod, Delta tool box. And it is NEVER CLEAN
I dont walk this way because of the wounds I have suffered in the line of duty, but because my balls are just that big!
03fathead6.0 is offline
post #7 of 12 (permalink) Old 10-02-2012, 04:27 PM
OBS Stroker
Nodge's Avatar
Yes, they only came with a 5 speed in a short box super cab if it was 4x4.
You could get an auto with a two wheel drive short box super cab.
1997 F250 ECSB, 140Kmiles, 3.55's, 5 spd, Sht throw, S.B. dd clutch, Rosewood 238/100, Adrenaline, S468, irate mount, ARP studs, 910 springs, smith bros. p/r, 4" MBRP, AFE Stg 2, BDP tunes, Termi Scan gauge, Swamps IDM, intercooled, BDP fuel
1997 F250, CCSB, swamps idm, 3" dp, 3.5" cat delete, 38gal rear tank.
Nodge is offline
post #8 of 12 (permalink) Old 10-02-2012, 04:36 PM
Talking Re: did i do okay buying my firstpowerstroke?
You are right, mine is one of those.
To the OP, you get a good deal there. upload some pics
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #9 of 12 (permalink) Old 10-03-2012, 10:16 AM Thread Starter
i never knew that. i guess it must came with a stick always then. learn something new everyday. ya i thought someone changed it out because there was a auto instrument cluster they gave me with it in the back seat.
post #10 of 12 (permalink) Old 10-03-2012, 01:48 PM
STILL LEARNING
Bradbilt's Avatar
I am sure that is just the original cluster with the PDNR21 put in from the lightning cluster
Bradbilt is offline
