no power and a p0355 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 10-01-2012, 11:15 PM Thread Starter
clutzmi's Avatar
Exclamation no power and a p0355
i idled the truck this morning for about ten min, while i was loading up then went to work no problems got thirty feet from my shop and the truck starting running extremely rough i barley made it into the parking lot at first i thought the fuel just gelled up but then at lunch the p0355 (cam sync intermittent failure) popped up. i had a cam sensor put in a few years ago per a recall.
any help would be appreciated i left it at my shop for the night so i plan on tearing into it tomorrow. i am a mechanic but do not deal with many diesels
thanks in advance
Zach
97 F250 OBS 7.3 Turbo Diesel 4X4, ISPRO gauges (boost, pyro, trans temp), Boost fooler, BB mod, Custom DIY cold air intake, CCV mod, 3" Diamond Eye down pipe, 4" exhaust, no cat, no muffler, Fog Lights, wheels and 285/75/16 tires
clutzmi is offline
post #2 of 4 (permalink) Old 10-02-2012, 02:27 AM
Patrick Feeley's Avatar
Re: no power and a p0355
The CPS can and do go bad. I would probably replace it and see what happens. If you were still getting issues after that, I might consider replacing the connector (a replacement pigtail is available). Cheers!
Patrick Feeley is offline
post #3 of 4 (permalink) Old 10-02-2012, 04:15 PM Thread Starter
clutzmi's Avatar
Im sorry it was a p0344
clutzmi is offline
post #4 of 4 (permalink) Old 10-03-2012, 12:14 AM Thread Starter
clutzmi's Avatar
Re: no power and a p0344
ok now i am confused the tsb from ford says i should have a square wave pattern, which makes sense because it is a hall effect sensor, instead i have the pattern below which is a pattern and its consistent. i don't under stand any more help would be greatly appreciated
[IMG][/IMG]
clutzmi is offline
