pcm question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 10-01-2012, 02:56 AM Thread Starter
cody342b's Avatar
pcm question
ok so i need some help. I fried the pcm a couple months ago and have been trying to find one since and have had no luck. i sent the old one out to see if it could get rebuilt and it cant. tried buying a referbished one from a couple companies and have got screewd by them or they dont have any. The computer #'s are F7TF-12a650 Rc-Rh, DPC-312. the understanding i have about this whole ca, smog bs is that it has to do with the injectors being split-shots and the others being singles? If so would any of the tuning guys like dp, beans, php...etc be able to either a) take another easier to find pcm and program it to work b) program a computer to work with a different set of injectors
any information is helpful and appreciated, thanks
cody342b is offline
post #2 of 2 (permalink) Old 10-01-2012, 09:46 PM
Patrick Feeley's Avatar
Re: pcm question
You ould need to address the wiring harness issues as well since the California 97 PCMs are pinned out differently. Cheers!
Patrick Feeley is offline
