Hard starting, need advice - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 10-01-2012, 12:32 AM Thread Starter
Mr.Wonderful's Avatar
I have a '96 F-250 with about 100k miles on it. Lately the first start up of the day has been difficult. I checked other forums on here and it seemed like it was either the glow plugs or relay. I replaced both with motorcraft parts. The truck still just cranks. I cycle the plugs two or three times and it starts to smoke out the pipe. Eventually it fires up after three or four tries and billowes black and white smoke for a second then clears up. I only drive the truck once or twice a week. This is a fairly new problem. Also I have noticed the inside of the tail pipe now looks damp and oily. Sometimes the truck blows a little faint white smoke until the engine warms up. The temperatures here have been mild maybe in the lower 50's at night.
Any advice is appriciated.
1996 F-250 ex cab 4x4 100k miles. DIY intake from Riff Raff Diesel. 3"-4" diamond eye turbo back
Mr.Wonderful is offline
post #2 of 10 (permalink) Old 10-03-2012, 06:00 PM Thread Starter
Re: Hard starting, need advice
Anyone......????
post #3 of 10 (permalink) Old 10-03-2012, 07:59 PM
Bugman's Avatar
Have you tested the relay and glow plugs? What happens when you plug the block heater in for a couple of hours before you start the truck?
Bugman is offline
post #4 of 10 (permalink) Old 10-03-2012, 10:48 PM Thread Starter
The relay and glow plugs are brand new. I will see if they are getting any power to them. And I will try the block heater.
post #5 of 10 (permalink) Old 10-03-2012, 11:57 PM
That doesn't answer the question of whether you've tested them. Brand new parts can be faulty, and brand new perfectly good parts can be installed into faulty circuits.
madpogue is offline
post #6 of 10 (permalink) Old 10-04-2012, 02:44 AM Thread Starter
Sorry for the confusion. No i did not test them....yet. I will do so asap and post the results. I'm also going to check the battery cables and terminals.
post #7 of 10 (permalink) Old 10-05-2012, 09:10 PM Thread Starter
Ok I checked the GPR and in the process I noticed the terminal ring was getting proper voltage. However the copper post was no reading any voltage. I cleaned the terminal ring bolted it back on and it fired up immediately...... I am still getting the grayish haze coming from the exhaust untill the engine warms up. Is this normal? Also I have noticed since I have had the truck the temperature gauge has never gotten past the "N" in normal. I have not done any towing or heavy hauling other than a yard of dirt a few times. Again I am still new to diesel and just wondering if this is an indicator of something needing attention?
post #8 of 10 (permalink) Old 10-05-2012, 11:25 PM
Bugman's Avatar
A little bit of smoky haze is normal on start ups when the temperatures are a little bit cooler. As long as they clear up it is no problem. My temperature gauge never did move above the N in normal until I put in a 203 degree thermostat and now it runs between the R and M. Just a FYI diesels run a lot cooler than a gas engine, they will actually cool down if you just sit in one spot and idle them for a while.
Bugman is offline
post #9 of 10 (permalink) Old 10-07-2012, 06:15 PM Thread Starter
Thank you for all the info. The vets on here sure take care of us newbs What benefits do you get from using the higher temperature thermostat?
post #10 of 10 (permalink) Old 10-07-2012, 11:13 PM
Bugman's Avatar
In theory the engine will run better and give you better mileage. Some will say that it does and some will say that it doesn't. You can read about it here on the Diesel Site Web site.
I have only had it in for a few months and haven't really tested it enough to form a opinion one way or another.
Bugman is offline
