Best MPG yet - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 09-30-2012, 02:18 AM Thread Starter
Best MPG yet
I topped off both tanks this morning and headed from Snohomish WA to Yacolt near Battleground. I drove to Seattle averaging about 70mph. I picked up a good friend to ride along and made out way south through Tacoma, Olympia towards our destination. I set the cruise at 65mph on the truck speedometer. My gps averaged 62 to 63 mph and fluctuated between the two. At Woodland we exited I-5 and headed towards Yacolt to pick up a swaybar and mounts for my truck. Backroads speed averaged 40mph up and down hills and I had the transmission locked out of overdrive. After collecting used parts we headed home. At Dan's house in Seattle my front tank mileage was 360 miles. I dropped him off and headed N to Snohomish. I switched tanks at 385 miles on the front tank. When I made it to town I stopped and topped off the front tank at 17.5 gallons. My average fuel economy was 22mpg. I think I could do better with a little less speed and less backroads being travelled. I know I could possibly pull down 23 mpg driving the interstate. Today was my best fuel economy to date.
ToddM715 is offline
post #2 of 18 (permalink) Old 09-30-2012, 03:54 AM
Moderator
PsRumors's Avatar
Re: Best MPG yet
Sounds good. 2 or 4 wheel drive?
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #3 of 18 (permalink) Old 09-30-2012, 05:17 AM
psdmike's Avatar
Re: Best MPG yet
Dang that is good. Need info on your truck.
1997 F350 Crew Cab, 7.3, 4x4, 5SP Short Shift kit, 5" RSK SD V Code springs, DIY Intake, 5" Exhaust with 30" FTE Resinator, intercooled, TS chip.
psdmike is offline
post #4 of 18 (permalink) Old 09-30-2012, 05:29 AM Thread Starter
Re: Best MPG yet
Maybe someone could clue me in how to fill out my signature. I would like to add my trucks Mods. 1995 f-250 cc 4wd. Auto, 4.10 gears. Tymar, 3" dp 4"exhaust. Valve body, Tru-cool, trans filter. Oil bypass filter, evans coolant and filter, full guage package. In progress 2.5" pmf reverse shackle superduty v&B code springs dana 60. Soon to come ccv mod and some sort of tuner. As far as I know it is running stock tune. Previous owner kept the tuner. I have all the service records since new. I wanted a f-350 four door but settled for 250 cc because I found a low mileage clean used one with all the service records and window sticker. I love the truck just not the color. Tire size is 2558516 on stock alcoas.
ToddM715 is offline
post #5 of 18 (permalink) Old 09-30-2012, 06:23 AM
Re: Best MPG yet
Thats really good why change it.
1996 F-250 PSD 4x4 5 sp. 4" TBE, bhaf, beans diesel 6 position chip. Needs injectors and an innercooler so bad. Low end TQ SUCKS! Even with 4:10s
OSB STROKED is offline
post #6 of 18 (permalink) Old 09-30-2012, 07:13 AM
Re: Best MPG yet
I just came back from Medford to Vancouver, Wa. Only got about 19mpg. Damn. Nice job! I think your 255s really help the mileage. Mike
'97 PSD, Cali truck. 2 wheel drive, Ext Cab, Auto. Baby Swamps, T.S. Chip. New glows plugs (ZD11). 273,000 mi. 3in down pipe. Cat & Muff Delete, (Love hearing the Turbo) Gauges, 6637 intake. New UVCH. Black CPS. Turbo next. But which one? In Vancouver, WA
voodoomaker is offline
post #7 of 18 (permalink) Old 09-30-2012, 11:27 AM
psdmike's Avatar
Re: Best MPG yet
Click the user cp button on the top left hand side under the home button. Then click edit signature under settings. There you can add info about your truck.
psdmike is offline
post #8 of 18 (permalink) Old 10-01-2012, 01:15 AM
Re: Best MPG yet
I once drove 55-60 mainly highway on that run and got 24 so speed does help a little. But it was hard to go only 55. Normally I get 18 driving 80 on highway and a lot of country hilly driving.
3in DP, 4 in straight, e fuel, Regulated return/ bowl delete, air dog 165, banjo bolts drilled out, ts 6 pos chip, HPX line, intercooler, EBPV delete, CCV mod, Valair Clutch
btomassacci is offline
post #9 of 18 (permalink) Old 10-01-2012, 01:24 AM
Been there....... done it
smokey73's Avatar
Re: Best MPG yet
I seem to be averaging 16-18mpg while keeping it under 75 mph on the Highway. The truck is all stock, even the 235/85's. It's a 4x4 auto with 4.10's. I guess I should really look into a downpipe and even an airfilter huh?
'97
F-350 CCLB 4X4 206k
Homemade 6637, Wicked Wheel II, 1.0 AR exhaust housing, DIY E-Fuel, FFD Stage 1's, TS 6 w/TW tunes
3" turbo back, 2.25" PMF RSK w/SD "U" codes, Remote CCV, Glow Shift Gauges
smokey73 is offline
post #10 of 18 (permalink) Old 10-01-2012, 01:25 AM
Re: Best MPG yet
16 is the beat I get
: 97 f350 cclb drw 300,000 miles stage 2 160 100 sticks 17* hpop sd ic turbo set up off a t444e sd fuel pump ts chip cat fuel filters stage 3 ceramic clutch 410 gears 3 in down pipe to 4 in out the back 6637 air filter all the gauges fuel hpop pyro boost oil temp 50 gal fuel tank
woodking is offline
