Rear Diff Fluid - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 16 (permalink) Old 09-29-2012, 03:14 PM Thread Starter
JRF
Rear Diff Fluid
I want to change my rear diff fluid and noticed guys here are using 75w-140. My owners manual says 80w-90. Did Ford put out a TSB and change the specs?
96 F250 XLT SCLB 4X4 E4OD
JRF is offline
post #2 of 16 (permalink) Old 09-29-2012, 03:29 PM
PMS medication required
joedown's Avatar
Re: Rear Diff Fluid
Many are using full synthetic which is readily available in the 75w-140. If you have a limited slip diff don't forget the additive.
96 F350 4x4 XLT 7.3 76,472 orig miles, Stage I's, Adrenaline, IDM, EBPV, Tymar intake, Banks intercooler, downpipe, gauges, TW 6 position chip, John Wood Towmaster, 1.0 turbo, WW II, Electric fuel conversion, RSK, OH console, Durn cat done run off an I can't find it.
joedown is offline
post #3 of 16 (permalink) Old 09-29-2012, 04:22 PM
Patrick Feeley's Avatar
Re: Rear Diff Fluid
There was something out there from Ford on it, but heck if I can find it (which bugs me ... so I'll keep looking!). Cheers!
Patrick Feeley is offline
post #4 of 16 (permalink) Old 09-29-2012, 11:02 PM
Coueshunter's Avatar
Re: Rear Diff Fluid
75w 140 is very common in rear diffs when they get worked or see 4wd action a lot
Back the Blue BUILD THREAD
POWERSTROKENATION-
Facebook-
Coueshunter is offline
post #5 of 16 (permalink) Old 09-29-2012, 11:33 PM
1 Slo PoMoFo
Ranger50's Avatar
Re: Rear Diff Fluid
I used 75w140 when I just changed mine a few months ago. I had a poop load of it left over from not needing it on all the Jeep axle rebuilds and changes. I still have yet to put any whale sperm in the fluid, but I have only driven it 12 miles since changing the fluid.
"Never trust an intelligent man with no money to play fair."
97 F250. 213k. Just about as stock as stock can be. Cali mod. Yard ornament.
Ranger50 is offline
post #6 of 16 (permalink) Old 09-30-2012, 02:01 PM Thread Starter
JRF
Re: Rear Diff Fluid
Thanks for the responses. I'm gonna go with 75w-140.
JRF is offline
post #7 of 16 (permalink) Old 09-30-2012, 03:41 PM
zilla68's Avatar
Re: Rear Diff Fluid
what about the front? same thing?
also, using mobil1 I see about a 9-10 dollar difference in the 140 being more money vs the 75w-90, I think I saw 75w-90 for rear and 140 for front, or vice versa, can't we just use the same thing front and rear?
Chris
Moore, Oklahoma
1996 Ford F350 4x4 Crew Cab PSD
6637 tymar
285-75-16 BFG All Terrains/Weld Wheels
3:55 gears
Automatic with billet convertor, tugger and alto discs
New Gearhead Tunes:
1 heavy tow
2 stealth mode
3 tow/econ
4 street perf
5 all out
6 high idle
1.0 housing
exhaust
zilla68 is offline
post #8 of 16 (permalink) Old 09-30-2012, 04:26 PM
Re: Rear Diff Fluid
Usually 140 in the rear and the 90 in the front. Some use 140 in both but usually on hard driven 4x4s. In most of our trucks the 90 in the front will be fine.
FYI the wal mart brand synnthetic diff fluid ranks VERY high and is very good oil
POWERSTROKENATION-
Facebook-
post #9 of 16 (permalink) Old 10-01-2012, 12:24 AM
Terminator Nation
Re: Rear Diff Fluid
The 140 Synthetic is recommended for heavy duty use in the rear in the factory service manual.
old man dave is offline
post #10 of 16 (permalink) Old 10-01-2012, 01:24 AM
OEM Moderator
Tom S's Avatar
Re: Rear Diff Fluid
Do you have a link to some reading on that? It is definately less expensive.
Tom S is offline
