Cold Start Smoking - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 29 (permalink) Old 09-28-2012, 04:33 PM Thread Starter
CumminsTrader's Avatar
Cold Start Smoking
All,
Wanted to bouce something off of you as I am going through my diagnostics. My '95 smokes a visible amount continually following a cold start up ( 40's and lower). The truck starts and idles nicely with no hesitation. The glow system and harnessing has been gone through and proven to work properly. It runs fine. When the temp begins to rise in the engine, the smokes becomes less and less until it completely quits. It is definitely fuel smoke (grey color and smells of unburned or partially burnt fuel) not oil or coolant related. I am going to try plugging in the block heater and see if this changes the smoking or conditions. This would signify it is cylinder wear related. I would expect if it is cylinder wear related, I would have smoking at some level all the time. The truck has been well maintained all of its life. So my thoughts are how likely are the possible causes:
1. My coolant temp gauges fluctuates and stays "cold" due to an electric wire issue. I know it is a break in the wire, I just haven't located the break yet. Could this command enriching and that is excess fuel? Is there only one coolant sensor for the dash and the ECM?
2. Could it be a HPOP wear issue causing a poor spray pattern with the thicker oil, which causes poor combustion? I can try and plug the oil heater in only, and see if that changes it.
3. What about injectors. I have seen videos and read some thread that described the same issue and the injectors were found to be either worn or failed, leading to smoking at startup.
As far as general engine health, EGT and boost are in their proper ranges during operation such as towing. Power is good and it starts well. Oil consumption is what I would deem normal from my experience from working in a shop on a fleet of T444E equipped commercial trucks. I have to add 1-2 quarts or less between oil changes. The truck is really only used for towing our toy hauler RV and I work it hard. I never usually have to down shift out of 5th and keep the cruise at 65-70mph pulling about 7500lbs worth of trailer.
Thoughts to what it might be?
cory
1995 F350 CC DRW XLT 2WD 5-Spd w/ BD Exhaust Brake 225K Mi, HyperMax Stage 2 Kit, HyperMax EGT & Boost Gauges, Riffraff / Tymar Intake, HyperMax Intercooler, HyperMax 330HP chip, Adrealine HPOP & Braided Lines, Melling M208 LPOP and HyperMax 4" Exhaust. Coming Soon: DP-Tuner F-6 and custom electric fuel system.
CumminsTrader is offline
post #2 of 29 (permalink) Old 09-28-2012, 06:08 PM
Here for the Ride!
devinferg's Avatar
Send a message via MSN to devinferg
Re: Cold Start Smoking
Honestly if it clears up once it warms up then it sounds pretty normal of a cold start for a 7.3. My 97 always smoked like that when i first started it in the morning on days that it was relativly cool out. I have several buddys with obs that there trucks do the same thing too
1997 F350 Reg cab-Powerstroke 5 Spd 135k miles ts 6 pos chip diy k&n intake 4 inch exhaust autometer gs series pyro & boost gauges-SOLD
2001 F350 Reg cab- 7.3 powerstroke 157k miles Wicked Wheel 6 pos chip Full ATS transmission and 5 star converter 5" exhaust DIY traction bars ISSPRO gauges pyro boost and trans temp
devinferg is offline
post #3 of 29 (permalink) Old 09-28-2012, 07:16 PM
Yup , sounds normal.
My 97 always does it.
swaan is offline
post #4 of 29 (permalink) Old 09-28-2012, 09:18 PM
Robjesup88's Avatar
The 97 f250 i had and the current 97 f350 does the same thing also
92 F150 rcsb E4od 5.0 sold
97 f350 cclb E4od 7.3 sold
07 f250 King Ranch studs and deleted
Robjesup88 is offline
post #5 of 29 (permalink) Old 09-29-2012, 01:23 AM
<-Friends bike
You may want to test the EOT sensor as it compares to ambient air temp .. A sluggish(worn) IPR can cause this also ...
Rick....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
ActionRick is offline
post #6 of 29 (permalink) Old 09-29-2012, 01:46 AM Thread Starter
Rick,
Is there a temp vs. resistance chart somewhere? As far as the IPR testing, if my PCM hasn't had a calibration update to OBD2 calibration so I can't use my Scantool, how can I check it?
Cory
post #7 of 29 (permalink) Old 09-29-2012, 02:09 AM
<-Friends bike
Originally Posted by CumminsTrader View Post
Rick,
Cory
I have one on the work puter .. I can get it monday ,,,
There are scanner only tests for the IPR
Rick....
post #8 of 29 (permalink) Old 09-29-2012, 03:16 AM Thread Starter
Rick,
My Scantool just doesn't function with my truck. I know Ford has an update cal to allow OBD2 protocol tools to function with the PCM. I imagine this cal would unlock that feature set that I know my tool is capable of.
Cory
post #9 of 29 (permalink) Old 09-29-2012, 03:21 AM
<-Friends bike
You will need to be able to see IPR DC % & ICP % ...
Rick....
post #10 of 29 (permalink) Old 09-29-2012, 09:13 PM
<-Friends bike
See if this helps ...:
K Ohms__Volts____TempF___Temp C
826______4.75______-32______-36
785______4.75______-30______-34
575______4.73______-22______-30
525______4.72______-20______-29
365______4.68______-10______-23
300______4.65______-4_______-20
250______4.63______0________-18
192______4.6_______10_______-12
173______4.55______14_______-10
139______4.49______20_______-7
103______4.4_______30_______-1
98_______4.38______32_______0
64_______4.18______40_______4
59_______4.13______50_______10
43_______3.92______60_______16
37.3_____3.8_______68_______20
33.6_____3.73______70_______21
26.8_____3.53______80_______27
24.3_____3.44______86_______30
21.5_____3.32______90_______32
17.2_____3.08______100______38
16.1_____3.01______104______40
13.9_____2.84______110______43
11.2_____2.59______120______49
10.9_____2.56______122______50
9.34_____2.38______130______54
7.55_____2.11______140______60
6.28_____1.89______150_____ _66
5.34_____1.72_ _____158______70
5.32_____1.71______160______71
4.48_____1.52______170______77
3.84_____1.37______176______80
3.75_____1.35______180______82
3.17_____1.18______190______88
2.8______1.09______194______90
2.68_____1.04______200______93
2.2______0.88______210______99
2.08_____0.86______212______100
1.87_____0.78______220______104
1.56_____0.67______230______110
1.33_____0.59______240______116
1.19_____0.53______248______120
0.38_____0.17______CEL Below This
________________________________________
Rick....
