Best Oil Pressure Switch Location - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 09-27-2012, 11:21 PM Thread Starter
Shovel's Avatar
I've searched endlessly to find a legit location to mount an oil pressure switch and only seem to become more confused than before I started. What I've learned is there might be multiple plugs and they should be near the oil filter location. With that said, which of the below are valid locations and what is the best one to mount a oil pressure switch for disabling an electronic pump in the event of a crash, etc.
Shovel is offline
post #2 of 9 (permalink) Old 09-29-2012, 03:38 PM
PMS medication required
joedown's Avatar
Re: Best Oil Pressure Switch Location
I put mine on the oil cooler.
96 F350 4x4 XLT 7.3 76,472 orig miles, Stage I's, Adrenaline, IDM, EBPV, Tymar intake, Banks intercooler, downpipe, gauges, TW 6 position chip, John Wood Towmaster, 1.0 turbo, WW II, Electric fuel conversion, RSK, OH console, Durn cat done run off an I can't find it.
joedown is offline
post #3 of 9 (permalink) Old 09-29-2012, 05:20 PM Thread Starter
Shovel's Avatar
Ah ha! A picture truely is worth a thousand words. Thank you much.
Shovel is offline
post #4 of 9 (permalink) Old 10-26-2012, 02:39 AM Thread Starter
Shovel's Avatar
BTW, where did you get that boot?
I wrapped my wires in electrical tape and it has done a real good job as a water holding tank.
Shovel is offline
post #5 of 9 (permalink) Old 10-26-2012, 04:32 AM
Demon Dually
speeddemon31176's Avatar
Looks like the boot for the power wire off the back of the alternator.
speeddemon31176 is offline
post #6 of 9 (permalink) Old 10-26-2012, 06:56 PM
Would this also be a good place to put in an oil temp sensor??
C bar M is offline
post #7 of 9 (permalink) Old 10-26-2012, 09:49 PM
Demon Dually
You could do that too. You could even put a "T" in that spot and have both the hobbs switch and a temp sender there.
post #8 of 9 (permalink) Old 11-05-2012, 04:21 PM
joedown's Avatar
Boot is from the back of a foreign car headlight, don't remember the make. I don't think it was any Asian made vehicle. If you don't have a boot I would not put tape on it but just leave it bare.
joedown is offline
post #9 of 9 (permalink) Old 11-05-2012, 05:47 PM Thread Starter
Shovel's Avatar
Noted. Thanks!
Shovel is offline
