Map sensor - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 31 (permalink) Old 09-27-2012, 01:10 AM Thread Starter
Map sensor
Ford wants $378 for the Map Sensor. Holy $$$$! What's a better alternative? Mike
'97 PSD, Cali truck. 2 wheel drive, Ext Cab, Auto. Baby Swamps, T.S. Chip. New glows plugs (ZD11). 273,000 mi. 3in down pipe. Cat & Muff Delete, (Love hearing the Turbo) Gauges, 6637 intake. New UVCH. Black CPS. Turbo next. But which one? In Vancouver, WA
voodoomaker is offline
post #2 of 31 (permalink) Old 09-27-2012, 01:54 AM
STILL LEARNING
Bradbilt's Avatar
Re: Map sensor
Used
Bradbilt is offline
post #3 of 31 (permalink) Old 09-27-2012, 03:14 AM Thread Starter
Re: Map sensor
uh, I already have a used one..
post #4 of 31 (permalink) Old 09-27-2012, 03:34 AM
STILL LEARNING
Bradbilt's Avatar
Re: Map sensor
Is there something wrong with it?
Bradbilt is offline
post #5 of 31 (permalink) Old 09-27-2012, 03:49 AM
Bugman's Avatar
Re: Map sensor
Is the used one on the truck now?
If you want a new one 1996 Ford F-250 Parts - Tousley Ford Parts Depot has them for just less than $200.00
Bugman is online now
post #6 of 31 (permalink) Old 09-28-2012, 02:25 AM Thread Starter
Re: Map sensor
The one thats in the truck is the stock one, used and not working properly. I'm getting code 268 anytime I hammer down or go up hill. Mike
post #7 of 31 (permalink) Old 09-28-2012, 02:42 AM
STILL LEARNING
Bradbilt's Avatar
Re: Map sensor
What the hell is a 268? Dosent come up in any of my searches unless you own a duamax w a injector problem
Bradbilt is offline
post #8 of 31 (permalink) Old 09-28-2012, 03:08 AM
Bugman's Avatar
Re: Map sensor
If it is 0268 here is what I got for the code:
0268 INJ Injector circuit high - Cylinder 3 FMEM mode, engine will run on 4 cyl. Miswired connector or harness
post #9 of 31 (permalink) Old 09-28-2012, 03:28 AM
Terminator Nation
Re: Map sensor
You can generally find the 7.3 sensors new on ebay cheaper.
old man dave is offline
post #10 of 31 (permalink) Old 09-28-2012, 04:15 AM Thread Starter
Re: Map sensor
Check that. Code 238. Isn't that associated with the Map Sensor? Mike
