Transfer case fluid? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-26-2012, 01:34 AM Thread Starter
Moderator
PsRumors's Avatar
What fluid is everyone using for their TC? Local parts store has Mercon V and Dex/Merc.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #2 of 7 (permalink) Old 09-26-2012, 05:57 AM
'05 Excursion
Term3's Avatar
I have always, always, used whatever my auto trans has used. Well except for my old Jeep Quadratrac which sadly rusted away years ago. Black two door, power rear window, big block that accelerated like a friggin rocket and had such a nice exhaust rumble that it was almost better then sex listening to it. WAHHHH I WANT MY JEEP BACK.
Term3 is offline
post #3 of 7 (permalink) Old 09-26-2012, 01:45 PM
OEM Moderator
Tom S's Avatar
Re: Transfer case fluid?
I use mobile one atf in mine.
Tom S is offline
post #4 of 7 (permalink) Old 09-26-2012, 01:47 PM
7.3L F-250's Avatar
i use pennzoil for almost all my fluids
TJ
1997 f-350 7.3 powerstroke zf-5 3:55s diamond eye 5" straight pipe and 250,000 miles and counting
1978 f-350 getting some form of diesel transplant
7.3L F-250 is offline
post #5 of 7 (permalink) Old 09-26-2012, 01:48 PM
STILL LEARNING
Bradbilt's Avatar
Ford calls for Mercon, so what ever flavor you want to put in will work fine
Bradbilt is offline
post #6 of 7 (permalink) Old 09-26-2012, 01:50 PM Thread Starter
Moderator
PsRumors's Avatar
I have a 6 gallon case of Schaeffer's All trans for the BTS that is coming. After doing some reading I just plan on using the All Trans in the trans and transfercase.....hopefully there will be just enough.
PsRumors is offline
post #7 of 7 (permalink) Old 09-28-2012, 04:09 AM
Terminator Nation
BTS/4R100 pan/Torque convertor uses about 20 quarts, more if you have a V-10 or 6.0 trans cooler.
old man dave is offline
