VSS wire near cab? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-25-2012, 10:58 PM Thread Starter
Russ's Avatar
VSS wire near cab?
I'm looking to install an Overhead console with outside temps and compass out of an Explorer, and I need to tap into the VSS signal for the temp sensor to work right. Anyone know where I could tap into VSS WIRING in/near the cab, and what color it is in a 97 CC PSD? thanks.
Stormtrooper:: 1997 F-350 CC SRW PSD XLT 4X4: Baby Swamps, Wildman, SD Intercooler, CCV Mod, shimmed FPR, BTS, Baldwin air filter,triple pillar pod with Isspro gauges, 4" exh, SD dual tensioner mod, diamond cut headlights, Hadley air horns,
Russ is offline
post #2 of 7 (permalink) Old 09-25-2012, 11:08 PM
STILL LEARNING
Bradbilt's Avatar
Re: VSS wire near cab?
It needs a VSS signal?
I know they are red and green wires with tracers. You could probably pick it up at the PSOM at the back of the cluster
Bradbilt is offline
post #3 of 7 (permalink) Old 09-25-2012, 11:28 PM Thread Starter
Russ's Avatar
Thanks Brad. Yep it needs the VSS to correct for wind chill.
Russ is offline
post #4 of 7 (permalink) Old 09-26-2012, 04:49 AM
Patrick Feeley's Avatar
For a 97 it would be circuit 679. It is a Gray/Black Trace wire off the PSOM connector (I had it hooked up on my 94 with the Explorer console). Cheers!
Patrick Feeley is offline
post #5 of 7 (permalink) Old 09-26-2012, 03:01 PM
Desert Rancher's Avatar
As Patrick said, pull the dash console. It's not to difficult, done it several times. If you need instructions, let me know.
Splice into the wire there.
I added the temp console to mine and it looks nice.
~DR
97 F250HD (Cal. model) Auto, Ext. Cab XLT, 4x4, long bed
Desert Rancher is offline
post #6 of 7 (permalink) Old 09-26-2012, 09:43 PM Thread Starter
Russ's Avatar
Patrick do you have a pics of the install? Thanks for the help.
Russ is offline
post #7 of 7 (permalink) Old 09-27-2012, 04:00 AM
There should be a couple in "here". Cheers!
