Checking for electrical draw - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 09-25-2012, 10:29 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Any suggestions? I blew the fuse in my digital meter.
Bradbilt is offline
post #2 of 14 (permalink) Old 09-25-2012, 10:38 PM
EverettWV's Avatar
Re: Checking for electrical draw
Need a clamp on ammeter. They can read a lot higher amps.
Everett
1997 F-250 Heavyduty, Powerstroke, DIY Intake, 4X4, 5 speed, SWD 4:10 axle, 4" Flo-Pro SS Exhaust
Dana 60 conversion with PMF RSK with superduty V code springs, Rear superduty B code springs
EverettWV is offline
post #3 of 14 (permalink) Old 09-25-2012, 10:52 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
I didn't blow the fuse trying to test this truck, i blew it a while back
Bradbilt is offline
post #4 of 14 (permalink) Old 09-26-2012, 01:32 AM
Bugman's Avatar
This might sound dumb but did you replace the fuse?
Bugman is online now
post #5 of 14 (permalink) Old 09-26-2012, 05:27 AM
Demon Dually
speeddemon31176's Avatar
To test for electrical draw you will need an ammeter. A clamp on style is what you will need. Clamp it onto the positive cable going to the fender mounted solenoid. The meter will indicate how many amps are being drawn at that time. It is not uncommon to see up to a 2 amp draw in a vehicle normally. You then pull one fuse at a time to determine which circuit is causing the draw. From there you will need an electrical schematic to be able to trace the wiring.
speeddemon31176 is offline
post #6 of 14 (permalink) Old 09-26-2012, 01:33 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Still trying to locate one.
Yeah, my meter has a 10 amp setting, I really dont feel like buying ANOTHER meter just for amp draws
Bradbilt is offline
post #7 of 14 (permalink) Old 09-26-2012, 01:38 PM
Moderator
PsRumors's Avatar
I probably have one I can loan you. Flat rate boxes aren't that expensive but once you ship there and back you can find a good used meter.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, TW tunes, International WP, 203*, Isspro Gauges
PsRumors is offline
post #8 of 14 (permalink) Old 09-26-2012, 01:49 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
Hitting radio shack this am to try and find the fuses i need
Bradbilt is offline
post #9 of 14 (permalink) Old 09-26-2012, 01:56 PM
Moderator
PsRumors's Avatar
When I say I have one to loan, it is one that will do amp draw.
PsRumors is offline
post #10 of 14 (permalink) Old 09-26-2012, 02:02 PM Thread Starter
STILL LEARNING
Bradbilt's Avatar
I should of "borrowed" one of those from work before I got laid off
Bradbilt is offline
