97 stroke cali edition fuel pulse dampner delete help - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 36 (permalink) Old 09-25-2012, 01:29 AM Thread Starter
genius
Exclamation 97 stroke cali edition fuel pulse dampner delete help
I got a california model truck and the fuel pulse dampner had a pin hole leak so after pulling everything apart to get to the thing I put a plug in where it was located reinstalled with no leaks after test driving the line off the banjo fitting to the head began to leak I figured ok must not have tightened it so I did it again it leaked again so i replaced the o-ring on the fitting test drive number 3 it started leaking again now my question is after doing the pulse dampner delete would that cause my lines to the heads to experience too much pressure and cause them to keep popping off?
OVmike is offline
post #2 of 36 (permalink) Old 09-25-2012, 02:08 AM
biggreen96's Avatar
Re: 97 stroke cali edition fuel pulse dampner delete help
No it won't cause a pressure increase. Did you make sure both sides of the banjo fitting had the copper crush washer still installed.
96 cclb f350.
idm mod,
gauges-boost/pyro/trans temp
afe stage 2 intake
dp to 4" straight pipe
studs, springs, pushrods
srp1
intercooler
electric fuel convertion
238/100
dp-tuner f6
T-4 mount and s470.
biggreen96 is offline
post #3 of 36 (permalink) Old 09-25-2012, 02:35 AM Thread Starter
genius
yeah crush washers on both ends just keep popping the line on passenger side head
OVmike is offline
post #4 of 36 (permalink) Old 09-25-2012, 04:58 AM
biggreen96's Avatar
May want to replace the rubber washers in the fittings that go into the head
96 cclb f350.
idm mod,
afe stage 2 intake
srp1
intercooler
238/100
dp-tuner f6
T-4 mount and s470.
post #5 of 36 (permalink) Old 09-25-2012, 05:37 AM Thread Starter
genius
just did that so far so good
OVmike is offline
post #6 of 36 (permalink) Old 09-26-2012, 03:08 PM
Desert Rancher's Avatar
Why did you not replace it? I think it just evens out the flow of fuel for the split shots. Don't think it changes pressure at all.
It was about $65 when I bought one last year.
~DR
97 F250HD (Cal. model) Auto, Ext. Cab XLT, 4x4, long bed
Desert Rancher is offline
post #7 of 36 (permalink) Old 10-03-2012, 02:46 PM
Question Re: 97 stroke cali edition fuel pulse dampner delete help
~DR
Do you have the part #?
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #8 of 36 (permalink) Old 10-03-2012, 09:35 PM
Patrick Feeley's Avatar
Here's some numbers for you:
Fuel Line Damper (96/97 CA; mounts on lift pump banjo fitting)
(Ford)F6TZ-9N163-AA
Fuel Line Damper Gasket (96/97 CA; copper washer; not included w/damper)
(Ford) F6TZ-9160-AA
Cheers!
Patrick Feeley is offline
post #9 of 36 (permalink) Old 10-04-2012, 12:07 AM
Thumbs up Re: 97 stroke cali edition fuel pulse dampner delete help
(Ford)F6TZ-9N163-AA
(Ford) F6TZ-9160-AA
Cheers!
I knew that Patrick had the part#. Thanks a lot.
post #10 of 36 (permalink) Old 10-04-2012, 04:54 PM
I got mine here:
Tousley Ford Parts Depot
The damper is called an "Accumulator"-$60.50
The gaskets were $2.31/ea
~DR
