Strange Oil Leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 09-24-2012, 10:55 PM Thread Starter
Loves OBS Trucks
MustangMatt96GT's Avatar
Strange Oil Leak
So I have seen oil under my truck the last couple days. Finally got time to take a peak under there.
The valley is bone by the fuel pump and under the turbo (just redid the fuel system in this anyway cause of a leak)
The turbo pedistal doesnt look like its leaking, the EBPV doesnt look like its leaking. So I climbed under it to look. Rear of the head on the passenger side is dry the plugs look fine.
Can't see the rear of the drivers head, but rand my hand around up there and it feels dry. The plug on the side of the head is dry, and its not leaking from the valve cover.
You can see it leaking right under the manifold donuts back there on the ear of the bellhousing.
I know its oil too, dip stick is reading low now.
Any ideas?
1997 F350 CCLB 4x4
1999 28' Classic Dominator
1996 Mustang GT with a Blown 351 with Stalled C4
MustangMatt96GT is offline
post #2 of 19 (permalink) Old 09-25-2012, 09:18 AM
Terminator Nation
Re: Strange Oil Leak
High pressure oil gallery oring boss plug has leaking o-ring? There are several plugs on each head.
You may try packing the engine valley with rags, run engine and then check for the wet spot.
old man dave is offline
post #3 of 19 (permalink) Old 09-25-2012, 04:34 PM Thread Starter
Loves OBS Trucks
The valley is dry as a whistle.
My initital thought was the HPO plugs in the back of the head but I couldnt feel anything. Im gonna take a look with a mirror as soon as I can now.
Oil cooler is not wet at all either.
1997 F350 CCLB 4x4
post #4 of 19 (permalink) Old 09-25-2012, 05:13 PM
STILL LEARNING
Bradbilt's Avatar
Off topic, but where did you put your oil filter and why?
Bradbilt is offline
post #5 of 19 (permalink) Old 09-25-2012, 06:30 PM
whistle tits
ghohouston's Avatar
X2 on oil filter question? And check your gallery plugs on side of the block, its just a male 1/4 plug. Also, is your dipstick nut on the side of the pan tight?
ghohouston is offline
post #6 of 19 (permalink) Old 09-25-2012, 06:31 PM Thread Starter
Loves OBS Trucks
It was like this when I got the truck. Has an amsoil kit on it. It goes out to the front bumper on the Ranch Hand. Two HUGE amsoil filters on it. It has a little drain valve too for oil anaylsis, but I dont do that. With the amsoil filters they are rated for 20,000 miles and are built specifically for the PSD diesels. I will go probably 7-8 with them and change it.
1997 F350 CCLB 4x4
post #7 of 19 (permalink) Old 09-25-2012, 06:32 PM Thread Starter
Loves OBS Trucks
From all the plugs I can see they look tight, The dip stick is not even close to where this one is leaking, but it is also dry. I am baffled by this leak.
1997 F350 CCLB 4x4
post #8 of 19 (permalink) Old 09-25-2012, 06:49 PM
old Smokey's Avatar
How about the corner of the value cover or your oil cooler for the leak.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #9 of 19 (permalink) Old 09-25-2012, 06:53 PM Thread Starter
Loves OBS Trucks
I have checked the valve cover, I didnt take it off but it isnt leaking from the valve cover.
The oil cooler is way further forward, but also it is not leaking, that was one of my first thoughts.
1997 F350 CCLB 4x4
post #10 of 19 (permalink) Old 09-25-2012, 07:16 PM
STILL LEARNING
Bradbilt's Avatar
Head gasket?
Bradbilt is offline
