No heat parked? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-24-2012, 10:51 AM Thread Starter
Bleeds IH Red
6.9PoweredScout's Avatar
No heat parked?
i noticed if i let my truck idle the temp will get to normal on the gauge but the heat coming from the vents isn't that hot, also the one heater hose gets hot and the other is cool . but the minute i start driving the heat gets hot coming out of the vents to the point you have to turn it off. anyone experience this???
-Jon
1980 IH Scout Terra
6.9L
1971 IH Travelette Crew Cab
DTA466 swap.
1991 F350 CCLB DWR 7.3L Banks Sidewinder/ E4OD 2WD
6.9PoweredScout is offline
post #2 of 11 (permalink) Old 09-24-2012, 12:57 PM
STILL LEARNING
Bradbilt's Avatar
Re: No heat parked?
May have a restriction in your heater core
Bradbilt is offline
post #3 of 11 (permalink) Old 09-25-2012, 06:14 AM
bracketracer's Avatar
Re: No heat parked?
Low coolant level? Air trapped in the heater core?
Newest project: 1995 F350 CC/DRW 2WD E4OD. 3" DP, 4" Diamond Eye system. But I'm still fixin' the broken stuff......
bracketracer is offline
post #4 of 11 (permalink) Old 09-25-2012, 06:25 AM Thread Starter
Bleeds IH Red
Re: No heat parked?
coolant is right inbetween the lines in the tank. i couldn't see it being air because as soon as i drive its hot.
-Jon
1980 IH Scout Terra
6.9L
DTA466 swap.
post #5 of 11 (permalink) Old 09-25-2012, 07:21 AM
Demon Dually
speeddemon31176's Avatar
Re: No heat parked?
Sounds like either a restriction or you water pump is not up to snuff.
speeddemon31176 is offline
post #6 of 11 (permalink) Old 09-25-2012, 10:52 AM Thread Starter
Bleeds IH Red
Re: No heat parked?
brand new napa waterpump.
-Jon
1980 IH Scout Terra
6.9L
DTA466 swap.
post #7 of 11 (permalink) Old 09-25-2012, 10:52 AM Thread Starter
Bleeds IH Red
Re: No heat parked?
i have a coolant filter in line with one heater hose, could that cause that much restriction??
-Jon
1980 IH Scout Terra
6.9L
DTA466 swap.
post #8 of 11 (permalink) Old 09-25-2012, 12:33 PM
The Sound Of Madness
dieselboy01's Avatar
Re: No heat parked?
Disconnect the filter and see if you have heat, that might be your problem. How long has that filter been in there? Maybe its plugged? My '00 sd gasser had that same heat problem, i had a cracked head and air was getting trapped in my heater core.
L99 SCSB 7.3 4x4 AEM intake, 5" straight pipe, 6pos Gearhead chip, Autometer gauges, Firestone bags, ATD Built tranny, Smoked lights, 15% tint, WW, Mr. Bobs boots & hoses, Leveled, Moto Metals
'02 F-250 RCLB 5.4 XL Plow truck
05 F-250 SCSB 6.0 XLT Plow truck
Remember kids, chrome wont get you home
dieselboy01 is offline
post #9 of 11 (permalink) Old 09-25-2012, 01:33 PM
STILL LEARNING
Bradbilt's Avatar
Re: No heat parked?
If it is on the filter side, I would say that is the issue right there.
Bradbilt is offline
post #10 of 11 (permalink) Old 09-25-2012, 08:55 PM Thread Starter
Bleeds IH Red
Re: No heat parked?
Filter hasn't been on there longer than 2 months.
-Jon
1980 IH Scout Terra
6.9L
DTA466 swap.
