97 psd fuel presure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-24-2012, 01:59 AM Thread Starter
97 psd fuel presure
ok boys.... i have a 97 psd thats givin me hell. First off i have a new filter in it and checked for air leaks the best that i can, so when i start it some times i have around 60psi and the longer it runs the fuel psi falls down to around 7psi what do u guys think is happening? when i drive it down the road it runs ok till it starts to miss and cut out from suckin the bowl dry re prime it up and head back home it just runs out again dunno if its the lift pump or what any ideas would be great. Also cleaned that screen behind the regulator
gooey is offline
post #2 of 11 (permalink) Old 09-24-2012, 02:06 AM
old Smokey's Avatar
Re: 97 psd fuel presure
Is the fuel tank air locked so that the lift pump can not pull fuel. You could try adding a BB to the pressure regulator to see if the fuel pressure still falls off.
96 with 320,000, Idm mod,
Tc mod, van turbo, 200/30 rosewood,
T 500 hpop, Dy 3" down pipe,
glowshift gauges, D60kp swap, custom track arms,
steering wheel swap, 6637 mod, Hydra chip, WW2,
calf fuel spring and BB mod
6.0 fan, cooler,
Pmf 2.25 rsk sd springs
78 f-150 turbo big block
old Smokey is offline
post #3 of 11 (permalink) Old 09-24-2012, 02:16 AM Thread Starter
i have the bb mod. and i took the lines all off down be the tank selector cuz i figured that to be the problem. so i bypassed that. also i could blow right through the lines the feed and the return.
gooey is offline
post #4 of 11 (permalink) Old 09-24-2012, 03:14 AM
old Smokey's Avatar
You could have bad injector o rings. How old or how many miles on injectors? How good are your rubber lines for the fuel system? At fuel filter housing and pump, also the return lines.
6.0 fan, cooler,
post #5 of 11 (permalink) Old 09-24-2012, 03:41 AM Thread Starter
i replaced all the rubber lines on the fuel bowl and pump. i think its gotta almost be that lift pump
gooey is offline
post #6 of 11 (permalink) Old 09-24-2012, 03:42 AM Thread Starter
as far as my injectors i have no idea i bought the truck w the odometer broke and no knowledge of them ever being messed with
gooey is offline
post #7 of 11 (permalink) Old 09-24-2012, 03:49 AM
Have you cleaned the screen on the fuel pressure regulator?
loudmouth is offline
post #8 of 11 (permalink) Old 09-24-2012, 04:16 AM
old Smokey's Avatar
If you have a lot of miles on the rig then I would say you are right in thinking the lift pump. For me the only time I have replaced them is when they start leaking in the valley. Replaced one at 198,000 and on another truck at 297,000. If you think there is say more then 200,000 on the truck then I would look at an injector.
6.0 fan, cooler,
post #9 of 11 (permalink) Old 09-24-2012, 04:22 AM Thread Starter
injectors will stop the truck from building fuel pressure? and yes i cleaned the screen
gooey is offline
post #10 of 11 (permalink) Old 09-24-2012, 07:14 PM
fieldtech's Avatar
Location: (Sweet Home, TX) 40 miles north of Victoria, TX
How long does it take for the preasure to drop that far? To me it sounds like the tank is air locked. pull the cap off the tank run it if that fix it clean your tank vent.
97, 7.3L F-250 CC 4X4 Auto, 133,000 miles, Gauges, 6637, TW Tunes, 5" Exhaust.
88, 5.9L F-350 EC 4X4 ZF5 Speed, Gauges, , HX35, 5X14 injectors, 6.0l Intercooler.
97, 7.3L F-350 RC C&C, ZF5
fieldtech is offline
