QUESTION!!!! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 09-23-2012, 11:59 PM Thread Starter
F-350 User
QUESTION!!!!
Is the injector pump and the high pressure oil pump the same thing?
Mues is offline
post #2 of 9 (permalink) Old 09-24-2012, 12:00 AM
7.3L F-250's Avatar
Re: QUESTION!!!!
no powerstrokes dont have injection pumps
TJ
1997 f-350 7.3 powerstroke zf-5 3:55s diamond eye 5" straight pipe and 250,000 miles and counting
1978 f-350 getting some form of diesel transplant
7.3L F-250 is offline
post #3 of 9 (permalink) Old 09-24-2012, 12:18 AM
whistle tits
ghohouston's Avatar
Re: QUESTION!!!!
you have a mechanical fuel pump, but it is not an injection pump, the high pressure oil pump opens and closes your injectors, and the fuel pump does just what its name indicates. what are you getting at with this? or were you just wondering?
ghohouston is offline
post #4 of 9 (permalink) Old 09-25-2012, 12:33 AM Thread Starter
F-350 User
Re: QUESTION!!!!
How would i go about testing my hpop?
Mues is offline
post #5 of 9 (permalink) Old 09-25-2012, 09:14 AM
Terminator Nation
Re: QUESTION!!!!
An Enhanced OBDII diagnostics tester can read out HPO pressure.
old man dave is offline
post #6 of 9 (permalink) Old 09-26-2012, 02:47 AM Thread Starter
F-350 User
Re: QUESTION!!!!
I've got a 94 Powerstroke so i have obd 1.
Mues is offline
post #7 of 9 (permalink) Old 09-26-2012, 05:36 AM
Demon Dually
speeddemon31176's Avatar
Re: QUESTION!!!!
You will need a high pressure gauge setup that can be screwed into one of the ports in the heads. There is a how to on how to build one on here.
speeddemon31176 is offline
post #8 of 9 (permalink) Old 09-26-2012, 01:57 PM
Find some one with an old snapon brick or one of the other scan tools that can read it
Sent from my SCH-I500 using AutoGuide.Com Free App
slandry786 is offline
post #9 of 9 (permalink) Old 10-20-2012, 01:00 AM Thread Starter
F-350 User
Re: QUESTION!!!!
Ok so I have narrowed it down to either my anti drain valve is stuck open or the o-ring on my stan pipe is bad. Anyone got any knowledge about how it check or change them?
Mues is offline
