Interested in a 97 f250 7.3l, few questions - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 09-23-2012, 12:17 AM Thread Starter
MrOneEyedBoh's Avatar
This would be my first diesel and I was wondering what should I be looking for when checking out a truck? Any specific sounds? start up issues etc? Are these best test driven on highway or stop and go , so I can recognize any issues? What about eh 7.3l in these years? Are they as stout as others, any common issues?
MrOneEyedBoh is offline
post #2 of 3 (permalink) Old 09-23-2012, 02:02 AM
STILL LEARNING
Bradbilt's Avatar
Re: Interested in a 97 f250 7.3l, few questions
Depending where you live, RUST can be a big problem.
As for the engine its self, Not too much in the way of problems.
If it starts and runs, that is 99% of it right there.
Pull the oil fill on the valve cover, flip it over and cover the hole with it. If the blow by blows the cap off, it is a lot. If not, then you will be fine.
Look for oil in the coolant, signs of bad oil cooler or o-rings. Easy enough to fix, but can use it as a bargaining chip
Bradbilt is offline
post #3 of 3 (permalink) Old 09-23-2012, 02:26 AM Thread Starter
Thanks for the tips!
