stage 1's and 6 pos chip, odd behavior - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 09-22-2012, 11:15 PM Thread Starter
green bastard
cslimfu's Avatar
1995 f250 4x4 190,xxx miles auto tranny, tymar intake 3" downpipe and straight pipe back. Got stage 1's(160cc) and 6 posistion chip installed. In the stock setting it is undriveable as lack of power. It cant even get out of it's own way. Economy has tons of power, but shifts too much, as in 3 gear by 25 mph and when at half throttle when it shifts up, sometimes it shifts right back down and so on. Tow is undriveable as well. Daily has pretty decent power a little slower to react then econmy, but shifts much more desireable. Hot shifts good and makes about the same power as economy, but with more smoke. I just got a scan gauge and made a few runs in hot. At idle hpop is at 750ish, full pull spikes to 2900 then drops down to 1900. It's still dropping , but pretty slow and I am out of road doing damn near 100. Then check engine light is on and idle is like half the injectors aren't firing but still at good rpm. The hpop is then at 1800 at idle with service light on. Only ever had the light come on in hot setting after a good 10 seconds or longer time of being floored. Shut it off, then refire idle is smooth and hpop is at 750ish. I forgot to get pulse width and duty cycle and will do that tonight or tommorow.
Ok long back story out of the way. I have cleaned the connection to the computer perfectly, so that can be ruled out. I know those hpop #'s are low, could that be causing the dead peddal and check engine light and strange idle(only when a full pull has been done in hot setting)? I have a ####ty scanner that wont read any codes. The light only stays on till I turn the truck off. I know I probably need to check more parameters and get the thing scanned, but haven't got that far yet. I also am hoping someone will of gone through this and chime in and say " mine did the same thing and it was ...."
cslimfu is offline
post #2 of 7 (permalink) Old 09-23-2012, 12:28 AM Thread Starter
green bastard
cslimfu's Avatar
Re: stage 1's and 6 pos chip, odd behavior
Ok, 65% duty cycle and 3.6 pulse width at wide open in hot posistion.
cslimfu is offline
post #3 of 7 (permalink) Old 09-23-2012, 12:44 AM
Whos tuning?
02 f250
countryboyrob is offline
post #4 of 7 (permalink) Old 09-23-2012, 12:54 AM Thread Starter
green bastard
cslimfu's Avatar
Beans and injectors. I have talked to them a few times and they have been great. I feel bad bugging them because I havent had a scaner to test anything. They have offered to reflash using the economy setting as a guide until I can do more tests, but I don't want to go back and forth with it until I know what the problem is and correct it, then see how it runs.
cslimfu is offline
post #5 of 7 (permalink) Old 09-30-2012, 08:42 PM Thread Starter
green bastard
cslimfu's Avatar
So nothing jumps out? So also, whats a acceptable exhaust back pressure number, is 40 too high?
cslimfu is offline
post #6 of 7 (permalink) Old 10-11-2012, 07:49 AM Thread Starter
green bastard
cslimfu's Avatar
So still nothing?
cslimfu is offline
post #7 of 7 (permalink) Old 10-11-2012, 07:53 AM
Demon Dually
speeddemon31176's Avatar
First step is to find out what is causing the check engine light to come on. Get it on a quality scanner and find out what is wrong. Correct those issues then move on from there.
speeddemon31176 is offline
