lights on after d60 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 09-22-2012, 03:40 AM Thread Starter
Powerstroke n00b
Justincredible's Avatar
lights on after d60
swapped in a king pin dana 60 into my 95 psd and i have my emergency brake light on and my abs light on... and suggestions as to why?
1997 F-250 zf6, t-500 Hpop, Baby swamps, Beans D66 w/ 1.0, hydra, 6637 CAI, 6" exhaust. Kingpin D60
Boost, Oil pressure, HPOP Pressure, Water temp, Oil temp, Trans temp and EGT, fuel pressure
soon efuel and 3" plenums and intercooler.
Justincredible is offline
post #2 of 19 (permalink) Old 09-22-2012, 07:31 AM
Canadian Eh
16yrenthusiest's Avatar
Re: lights on after d60
Shouldnt have anything to do with the front axle as our trucks only have rear abs
96 F250 7.3, auto, eclb, D60 swap, TS 6 pos, diy intake, Flo-pro turboback, ccv mod, Isspro gauges, Detroit Truetrac, 16x10 eagles, 315/75/16 Fierce Attitudes
16yrenthusiest is offline
post #3 of 19 (permalink) Old 09-22-2012, 08:30 AM Thread Starter
Powerstroke n00b
Ik. But the lights werent on before... But swapped axle wnd bam theyre on... Ill have to get into it more today as it was done in the dark >.<
post #4 of 19 (permalink) Old 09-22-2012, 03:20 PM
Prolly brake fluid level or something stupid...
02 f250
countryboyrob is offline
post #5 of 19 (permalink) Old 09-22-2012, 04:15 PM Thread Starter
Powerstroke n00b
Probably. I was curious to feedback since i dis my swap with a flashlight since my d50 broke in half. Now that its light out im headed to the farm to try and figure it out.
post #6 of 19 (permalink) Old 09-22-2012, 06:47 PM
OEM Moderator
Tom S's Avatar
Did you have the brake lines undone?
Tom S is offline
post #7 of 19 (permalink) Old 09-22-2012, 08:20 PM Thread Starter
Powerstroke n00b
Yeah. For the front.. obviously if i swapped axles. But i broke a bleader valve trying to bleed them and i cant get it out so i just ordered a new caliper should be here monday
post #8 of 19 (permalink) Old 09-22-2012, 09:15 PM
STILL LEARNING
Bradbilt's Avatar
There is actually no need to open the brake system when swapping axles. Just hang the calipers off the frame and then reattach them to the new axle
Bradbilt is offline
post #9 of 19 (permalink) Old 09-22-2012, 09:17 PM Thread Starter
Powerstroke n00b
U cant bolt in a push pin caliper >.< so therefore having to open the system...
post #10 of 19 (permalink) Old 09-22-2012, 09:38 PM
tsanjose's Avatar
have u tried to clear it with an OBD reader? sometimes something trips and it turns out to be nothing at all.
'97 f250 eclb
auto trans
4" lift 35" toyo mt w/ 20x10 predator 8's
mbrp exhaust (3" dp, 4" thru, no cat)
polished intake w/napa 6637
dp f5 w/40 tow and 80hp econo tunes
autometer (pyro, boost and trans)
tsanjose is offline
