1997 7.3 ..will this thermostat work? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 09-20-2012, 04:05 AM Thread Starter
444CuiOBS's Avatar
Hey all,
I decided to change out my t stat and housing today. I picked up both at my local IH dealer. The question I have is regarding the t stat. The version the parts guy gave me was part number 1845804C2. (He looked it up) I installed it and it seems to open and close just fine, no noted issues with the cooling system. The t stat had the updated gasket, not the o ring style. Seated perfectly.
I'm questioning the t stat being correct because this version looks like a standard t stat... It doesn't have the long stem like the one I took out had. Looks like a gasser t stat actually.
I looked everywhere online to find any real reference to this part number.
Any ideas?
Thanks in advance
1997 Ford F250HD XLT SC, Tymar. Edge CS. Ford shim. DP to 4" straight. 140,000mi Cooper STT 305's Just finished cab/box off resto
444CuiOBS is offline
post #2 of 6 (permalink) Old 09-20-2012, 06:49 PM
Arrow Re: 1997 7.3 ..will this thermostat work?
Originally Posted by 444CuiOBS View Post
Hey all,
Any ideas?
Thanks in advance
I have this numbers in my list part:
Thermostat
(Ford) F4TZ-8575-A (engine serial no. 201680 & before) Motorcraft RT-1093
(International) 1812314C94 (94-95MY, 203F)
(Ford) F6TZ-8575-AAA (engine serial no. 201681 up to 98.5)
(International) 1824426C92 (96-99MY, 192F)
F-250 PSD 1996 ext.cab 2WD, Short bed, E4OD.
STROKER #1 is offline
post #3 of 6 (permalink) Old 09-20-2012, 06:59 PM Thread Starter
444CuiOBS's Avatar
Thanks Stroker, after digging some more i believe this t stat is for pre-96 7.3's. From what I read, the water pumps were redesigned beginning in 1996 with a coolant bypass, so the long stem is needed.
Thanks for the p/n.....i'm headed to IH!
post #4 of 6 (permalink) Old 09-21-2012, 02:08 PM
Thumbs up Re: 1997 7.3 ..will this thermostat work?
You are welcome. Good luck. Keep posting.
post #5 of 6 (permalink) Old 09-21-2012, 05:56 PM Thread Starter
444CuiOBS's Avatar
Got the new CORRECT t stat in place. I also replaced the thermo housing, cant believe is actually held water. RUSTY. Best of all, no leaks.
Also, my local International dealer didn't stock the thermostat I needed, had to run up to the stealership @ $58.
I'm guessing Ford uses their own water pump design than Int'l uses for the T444E?
post #6 of 6 (permalink) Old 09-21-2012, 06:35 PM
Wink Re: 1997 7.3 ..will this thermostat work?
Glad its working fine. There are a special water pump from IH that its a little different that the stock ford WP, that has a built in filter.
