Starting problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 11 (permalink) Old 09-19-2012, 11:16 PM Thread Starter
kramarj's Avatar
Starting problem
So the past few times my dad would start up the other work truck we have it turned over very slowly and would barely start. Then he went somewhere and it wouldn't start, so I came and jumped it and it fired right up. So we bought new Napa batteries yesterday, threw them in, same problem. Threw the charger on them, still the same problem. So is the starter junk??? That is my next guess. Is it possible both the starter and batteries were junk??
Joe
97' F-250HD. ECLB. 65,000 miles. 7.3. E40D. 6637 Filter. 5" Exhaust. Deleted EBPV. CCV mod. 45 gal. Transferflow Rear Tank. Stock for now. Dana 60 in the works.
kramarj is offline
post #2 of 11 (permalink) Old 09-19-2012, 11:44 PM
Re: Starting problem
starter is prolly junk, these trucks take ALOT of juice.
02 f250
countryboyrob is offline
post #3 of 11 (permalink) Old 09-19-2012, 11:58 PM Thread Starter
kramarj's Avatar
Ok, thanks. Is there any way to make sure, because the batteries were kind of expensive, and I want to make sure. Could it be something stupid like the solenoid on the fender behind the battery causing problems?
Joe
kramarj is offline
post #4 of 11 (permalink) Old 09-20-2012, 12:03 AM
theoldgirl1990's Avatar
Does the starter make any attempt to turn over or does it just click?
1996 F-350 cclb, H2E, e-fuel, srp1.1, custom tuning, banks intercooler, 3 in plenums, swamps babies, ARP's, comp 910's, Isspro EV2's, rsk v/c codes, 5 inch exhaust, king ranch seats, SD 10.5 axle, swamps idm, 6.0 fan, international w/p, hydroboost, SD trans lines, 6.0 trans cooler,6.0 P.S. pump
theoldgirl1990 is offline
post #5 of 11 (permalink) Old 09-20-2012, 12:04 AM
My old 97 did the same thing, starter died while I was at my then girlfriends parents farm.......
If you do get a new start get a 03 7.3 starter.
02 f250
post #6 of 11 (permalink) Old 09-20-2012, 12:07 AM
7.3 fan
did you check and all the terminals both at batteries and other end?
99 f350 7.3 srw super cab 290xxx miles zf LUK clutch bully dog afe and 4" mrbp
00 f350 7.3 drw cc 165xxx miles 4" exhaust auto
00 ex 7.3 afe 4" MRBP 185xxx miles 4" exhaust
jestersv is offline
post #7 of 11 (permalink) Old 09-20-2012, 12:18 AM Thread Starter
kramarj's Avatar
The truck will turn over, just very very slowly, not enough to even fire, even with the new batteries. All the terminals are good, it has gotten slower and slower, which leads me to believe the starter is shot. Will the old starter work as a core if I get the SD starter?
Joe
kramarj is offline
post #8 of 11 (permalink) Old 09-20-2012, 12:20 AM
yep
02 f250
post #9 of 11 (permalink) Old 09-20-2012, 12:33 AM Thread Starter
kramarj's Avatar
Cool. Thanks for the help, a new starter it will be then.
Joe
kramarj is offline
post #10 of 11 (permalink) Old 09-20-2012, 06:23 AM
I purchased a sd starter from O'reilly and it lasted about six months. I decided to buckle down and get a factory motorcraft sd starter. Part number sa-903, it is a brand new unit and will cost ya, but may save you the headache later.
